FSM says the gap for my 2000 Vert is .060. I just bought NGK TR55's and out of the box they range from .058 - .060, which seems acceptable. Never hurts to check them.
Interesting. I have not installed the TR55's I just got, but I did pull one of my old plugs, and it's gap is also .060. I think the plugs in my car now are original. You would think if the .040 is the new recommended gap that they would come with that gap. I wonder why not? Now I am not sure what to do. What is the reason for the smaller gap? I just purchased my plugs along with MSD wires from a supporting vendor and they told me I do not need to change the gap. My car is stock, no engine mods.
Spark plug manufacturers don't always know what kind/brand of engine a particular plug is going in to. NGK TR55 is not just a plug for C5 Corvettes and I think the application listing by NGK actually does not include the C5. It has become popular among the higher horsepower guys, especially the boosted guys.
By application, the TR5 gapped at .040, is the plug NGK recommends for their V-power series plugs used in C5s (LS1/6).
There seems to be confusion on this question by a number of folks.
There are TR5 plugs which apparently run a bit colder and are gapped at .040 and then there are TR55 plugs which are theoretically gapped at .060.
From what I have read there is also a range of gaps that will be tolerated for each plug.
My post was specifically about TR55 plugs although it seems most of the responses are related to TR5 plugs. Supposedly, except for the gap, they are the same.
Since there is this confusion I guess it's best for me to check the gap in the old plugs and make an executive decision on what gap to ensure the new TR55 plugs are set at.
My car has some engine modifications and is tuned so perhaps the existing plug gap would be best to identify and use.
The GM bulletin reduced the gap from 0.060 to 0.040 when going from the GM platinum plugs to the GM iridium plugs. Since the TR5 and TR55 are neither, not sure if they should stay at 0.060. My understanding is the large gap is to reduce certain emissions at partial throttle cruise.
