Best shocks for lowered C5Z
If the suspension bottoms out, NO SHOCK in the world will help you. YES, Bilsten makes a very good shock.
Have you taken into account your alignment after lowering? It will need to be realigned!
Bill
I know that's not much info, but it's what I have.
Bill
I have had it lowered for almost a year now, and yes I have had it aligned after I lowered it, It has always been in spec when I have had it aligned twice this year. I have never bottomed out, but then again the roads I drive on are smooth and only drive it about 6k miles a year. Im just wanting new shocks for a better ride and that there almost 13 years old.
You are complaining about the ride quality and that is the first hint that you are already hitting the bump stops.... frequently. While these cars are firm, they aren't that bad, and if you have a rough riding car you're into the bump stops big time.
A half an inch of travel may help some, but really, to improve the ride you need to get rid of the Zip bolts, get some rear suspension travel and then any decent shock should ride pretty well.
As far as rear shocks go the C5Z shocks give the best ride due to their valving, but the Bilsteins aren't far behind and their slightly shorter length may make them work a bit better in your situation.
As Bill noted, if you're into the bump stops, it doesn't matter what shocks are on the car since they are just providing a place to mount the bump stops.
I'd get the ride height back up to within 1 inch of stock and then evaluate the ride quality with that setup first. You probably haven't worn out the OE shocks since they haven't been used much before this.
Fact is slamming any car is going to ruin the performance handling. Your best bet is to start saving for coil-overs.
If you go around a brisk corner the body roll is going to use up that inch of travel, and you are basically on the stops. Any bump after that results in nasty oversteer.
Bill Curlee has suggested a simple test, go around a on-ramp a bit briskly and if the rear of the car "steps out" you're on the bump stops.
Just because you can easily put in a set of bolts that will drop the car doesn't mean it's a good idea. The suspension geometry was designed to work the best when the car is lowered a little bit (3/4 of an inch to an inch) but after that handling deteriorates because the camber gain just isn't there, and of course bottoming upsets the car even more.
If you really want the car slammed, get a set of LG dropped spindles (best solution) or set of coilovers (second best solution) and you can have your handling and that slammed look that you like. Unfortunately, short of spending the big bucks you aren't going to get a decent ride with the car that low.
The Bilsteins don't seem to be any shorter but they have a complete POS bump stop that will just collapse and allow metal to metal contact. That is what gives those shocks more travel compared to using the stock bump stop.
