TPMS battery replacement question
Old Dec 27, 2014 | 11:01 AM
Mxzx's Avatar
Mxzx
Default TPMS battery replacement question
I'm in the process of putting new batteries in 4 TPMS's.
The batteries are the Renota 2477N's, same as OEM.
The batteries measure 3.25 volts before install. After I put them in, the voltage instantly drops to 1.2 volts. I let on sit all night on bench, and this morning it measured .8 volts?
I figured the 1.2 volts was when the sensor was transmitting, but shouldn't it shut off at some point, and return to 3 volts?
I just want to make sure these are right before putting the silicone on them.
TIA
Old Dec 27, 2014 | 12:54 PM
Voodoo13's Avatar
Voodoo13
That is not right. It sounds as if there is a current leak somewhere
Old Dec 27, 2014 | 06:51 PM
Mxzx's Avatar
Mxzx
Yeah, kinda what I was thinking.
I'll temp up another one and see what the voltage is.
Old Dec 27, 2014 | 08:50 PM
Mxzx's Avatar
Mxzx
I just checked all 4 on bench, with different batteries, and they all drop to 1.2 volts when batt is put in and leads connected.
The sensors worked before, so I don't think all 4 would be bad.
I'm gonna try to train one tomorrow and see if it will connect and how long it lasts!
Old Dec 27, 2014 | 09:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Where did you purchase your batteries from?
My wife purchased some portable phone rechargable batteries form an ON LINE SUPPLIER. They worked for about 2 weeks.
I purchased some different replacement batteries (singel sell, solderable together) from a known good dealer. The rechargable batteries have been working OUTSTANGING for months.
You could have bad batteries.
When the wheel is NOT rotating, the transmitter, should NOT be working and NOT drawing current. Put a DC Current meter MILLIAMP METER) between the NEG lead and the NEG sensor battery terminal and see if the device is drawing current all the time. It shouldnt!!!!!!!!!!
Bill
BC
Old Dec 28, 2014 | 08:57 AM
Mxzx's Avatar
Mxzx
Thanks for the reply.
I forgot where I bought them, but was online.
I did show the sensors around putting the batts in, that would activate them, correct?
I'll check the MA and see what's going on.
Old Jan 2, 2015 | 11:10 PM
toddk's Avatar
toddk
You can force them to transmit by placing a strong magnet near the base of the valve stem. This is also how you train them when inside the wheel rim. I've tested TPMS using O'Reilly's keyfob tester this way to visually confirm they are transmitting something.
Todd
Old Jan 2, 2015 | 11:22 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Todd
you can test the transmission function but you cant test the pressure function. IN my opinion. its not worth all that effort to try to replace the batteries and run the risk of a failed circuit board that can only be tested after they are installed and rotating up to speed.
Old Jan 3, 2015 | 12:41 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
2477N Lithium batteries are rated at 3 volts DC output. Something is definitely wrong if the voltage is dropping to 1.2 volts under load. Either the batteries are all weak, or a component in the TPMS circuit board was damaged during the battery replacement causing an excessive current load.
Old Jan 3, 2015 | 01:24 PM
Evil-Twin's Avatar
Evil-Twin
Over my years here, several members tried to make a home business out of replacing these batteries. Of the three people I know who made a go of this, none of them lasted more than a year. reason... too many failures, too much effort and grief for the return.
To TPMS battery replacement question
