Once they enter the pan,, there pretty much going to stay where they are at. The pan has shallow ribbed trays and once a pin settles into a tray,, its pretty much going to stay where its at.
If you install a magnetic drain plug, if any migrate as a result of acceleration or high G Force turns or going up hill, the magnet will retain it.
You could use a powerful magnet and run it under the pan and maybe pull any stray pins towards the drain plug.
The magnet will is your best bet.
Bill
I thought about doing that. Will go ahead and give that a shot.
This was on the passenger side, when I do the driver side for will I need to disconnect any fuel lines? I have an A&A secondary system.
The same thing happened to me. It was #7 on the driver's side. I bought the Comp Cams upgrade but haven't done it yet. That's a good over the Winter project. My car has a 7# supercharger boost.
I would drop the lower (batwing) part of the pan. Easy to do and wash it out properly. JMO. Oops seen that idea has been already mentioned. Yeah and you may not have a 2 piece oil pan... blah blah..lol Meh.. you will get it sorted out. It's not like you cracked a piston.
