AH/TC sensitivity
Old Feb 3, 2015 | 01:20 PM
Bluefire's Avatar
Bluefire
Originally Posted by dadaroo
If the SWPS is gong bad then he can blame AH. It is one of the 3 inputs to AH.
Then he can blame AH for the effect that was caused by the SWPS.
Old Feb 3, 2015 | 01:27 PM
Bluefire's Avatar
Bluefire
OP - Does Cruise Control disengage by itself?
Old Feb 5, 2015 | 04:40 PM
enoniam's Avatar
enoniam
I don't recall that it does. If it has it doesn't do it very often.
I've never set it at 110 mph.
Old Feb 5, 2015 | 05:21 PM
Bluefire's Avatar
Bluefire
Agreed. Never set it at 110.
The CC disengage was another major clue that my SWPS was going out.
Old Feb 6, 2015 | 03:53 PM
enoniam's Avatar
enoniam
Thanks! I'll keep my eye on it.
Old Feb 7, 2015 | 12:35 PM
lionelhutz's Avatar
lionelhutz
Curious where you learned there were 2 generations of AH/TC. I know it was first an option and then became standard in 2001 if I remember correctly. Would like to read.
In the service manuals they refer to the systems as version 5 and 5.3 so it was a newer version, but I wouldn't call it a whole new design. The hardware changed (a new way to build the valves was employed) but the sensors are the same and I would expect the software was just improved, not re-designed.
The "technology" in the steering wheel position sensor is the same brass contact sliding over a rheostat wheel that you find in a slot car. It may be that at 110 MPH the road vibration is able to cause the contact momentarily bounce off of that rheostat wheel. That can cause the AH/TC to engage.
Just a guess though.
It appears from the service manuals that the analog signal was used in the early EBTCM to calibrate the system when the car was first started and driven. The A and B encoder signals tell the system the wheel is turning and by how much. The later system doesn't even have the analog signal.
Old Feb 8, 2015 | 07:23 PM
racebum's Avatar
racebum
this was actually my guess on why those sensors act up after 100k miles or so, after you move them so much they get loose and will occasionally set codes even though they work fine most the time
Old Feb 8, 2015 | 07:26 PM
racebum's Avatar
racebum
it was completely new, no parts were carried over. bosch was the designer behind this. sensors are not the same. ebcm is different. steering sensor is different, yaw sensor, list goes on and on. the only part i'm not 100% on are the abs sensors as i have never checked.
Old Feb 8, 2015 | 08:57 PM
lionelhutz's Avatar
lionelhutz
Wheel speed sensors - same
Yaw rate sensor - same
Lateral accelerometer - same
SWPS - same A & B encoder signals. The new design only removed the analog signal
Magnasteer - same
Wiring - same wires, same colors, same fuses except removing the SWPS analog wire
PCM signalling - same
The BPMV and EBTCM were re-designed and the valves were a big change, as I posted before.
I would also bet money the code wasn't all new. Some re-writing and improvements, but not new.
So, did they throw out everything they did on the first generation and start with a fresh design? - No.
Old Feb 10, 2015 | 05:13 PM
enoniam's Avatar
enoniam
I found this reply from Lawdogg on the Z06vette forum that I found interesting:
"To completely disable it (AH) on a C5 you pulled the steering position wire plug off the bottom of the steering column. It was the only way to completely disable the active handling. Not sure if this would work on a C6. We learned this when the active handling system malfunctioned on the 2003 One Lap of America. It would engage and almost put the car off the track by putting the passenger side front brake on full for a split second every time we hit about 120 mph, even when the ach button was turned off. It would do this once every ignition cycle the first time the car went about 120. On a high speed track this was somewhat of a concern.
"We worked with GM and found out the active handling ran in the background even when turned off and would engage if it sensed something was really wrong. Only way to completely disable was to pull the steering position harness plug. It would set a bunch of codes relating to active handling but it would turn off the system."
Maybe I need to repeat my test with AH off first and then see if it repeats with it on in the same ignition cycle...
Old Feb 10, 2015 | 05:17 PM
enoniam's Avatar
enoniam
And this thread seems to also point towards the steering wheel position sensor:
http://ls1tech.com/forums/corvette-p...ing-issue.html
Looks like I need to check for codes...
