Trans-go Shift Kit Setting.
Old Aug 6, 2002 | 10:11 AM
wkasak_07Z06's Avatar
wkasak_07Z06
Default Trans-go Shift Kit Setting.
I am in the process of upgrading to 3.42 gears, SY3500 TC, Trans Cooler, programming, and Trans-go Shift Kit. I see the Shift Kit can be configured in four different settings. For those of you that have had this shift kit installed, which setting did you go with 1(street show off),2(heavy duty),3(pro-street), or 4(full race)?
[Modified by wkasak_98Coupe, 2:17 PM 8/6/2002]
Old Aug 6, 2002 | 10:34 AM
Fahtrim's Avatar
Fahtrim
Default Re: Trans-go Shift Kit Setting. (wkasak_98Coupe)
TTT - I am interested in this also.
Old Aug 6, 2002 | 11:14 AM
2001 Red Coupe Bandit's Avatar
Default Re: Trans-go Shift Kit Setting. (Speide)
I don't have it, but see what Everyone or I should say, the majority of the C5 guys are using with the TransGo.
It is 2 Spacers!!!!!!!!!!!!!!
The Bandit.......
[Modified by 2001 Red Coupe Bandit, 9:15 AM 8/6/2002]
[Modified by 2001 Red Coupe Bandit, 10:40 AM 8/6/2002]
Old Aug 6, 2002 | 12:52 PM
Lil Red's Avatar
Lil Red
I am interested in doing this mod as well. Hopefuly many will vote and comment on there experiences with this!
Old Aug 6, 2002 | 01:47 PM
eastco's Avatar
eastco
We have been using two spacers on the 1/2 accum, and one on the band with great results
Old Aug 6, 2002 | 02:23 PM
gojo's Avatar
gojo
Default Re: Trans-go Shift Kit Setting. (eastco)
Steve,
Is there anything to drilling the feed holes?
Do you combine your spacer useage with tuning changes to the tranny?
Old Aug 6, 2002 | 03:26 PM
eastco's Avatar
eastco
Default Re: Trans-go Shift Kit Setting. (jfpilla)
You have to drill one hole larger depending on convertor size and the two spacers seem to be fine with all others
Old Aug 6, 2002 | 03:45 PM
vstella's Avatar
vstella
What Steve said! :D
Old Aug 6, 2002 | 05:57 PM
ROD BROWN's Avatar
ROD BROWN
i have a Trans-go Kit in my 99,and I have 3 washers in it. The next time I have trannie serviced and the filter changed,I am removing 1 washer.A bit much for me.the wheels "chirp" even when I am driving normal.If I go around a corner,ahe wheels "chirp".Goin' to 2 as soon as I can. :chevy :chevy :flag :chevy :chevy
Old Aug 6, 2002 | 07:21 PM
BlackSun!'s Avatar
BlackSun!
Default Re: Trans-go Shift Kit Setting. (ROD BROWN)
I was told you don't need a kit for 2000 or newer..... Is this correct??
Old Aug 6, 2002 | 07:38 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Trans-go Shift Kit Setting. (BlackSun!)
I don't use one, but here is a quote from Yank!
Yank Performance Converters can achieve maximum performance and efficiency without the use of shift kits. Shift kits dramatically raise transmission line pressure to increase shift firmness. Increased shift firmness will not increase performance, but create unnecessary stress on the transmission and other drive-line components.
To Trans-go Shift Kit Setting.
