RPM dependant vibration/buzzing
This is what I tried when I was there to narrow it down:
Speed: moving or not, it didn't matter, only RPM.
Clutch: Clutch engaged vs disengaged, no difference.
RPM: 2500-3000 is where it is active.
Mods on car:
A&A Supercharger, V2
LG Super Pro Long tube headers and X pipe, Borla stingers
Conclusions on my end:
Harmonic balancer: ( I notice a slight wobble at idle on the original GM balancer)
Headers: Could be caused by the headers rubbing or touching on something, I will check this out.
What else? Torque tube? I figured I would write that off as it is not speed dependent at all.
Thanks for any input.
I agree... If you are stopped and in gear with the clutch DEPRESSED,, The TT prop shaft is NOT moving.
It wasn't until I drove it this weekend I noticed the vibration, chances are that it could have been there the whole time.
It does have a clutch, that was installed in 2010, at the same time the TT was rebuilt. I have receipts from the previous owner getting this done.
I am going to check the exhaust as that would be the most obvious thing, but beyond that I am somewhat short on ideas except the HB.
What is the best way to diagnose the flywheel/clutch?
I wonder if this is where my issue is..
It doesn't say anything about balancing the clutch and fly wheel on the invoice. I suppose I could drop the clutch inspection cover, and go to town and try a hot balance by adding washers to the PP bolts?
Any other ideas would be appreciated.
With the car at rest, put the car in neutral. Rev the engine to the rpm range that seems the worst. Put your hand on the shift ****. Then keep revving at that rpm and depress the clutch pedal. Are the vibrations still present with the clutch pedal depressed? if so, the propshaft is not spinning, so it's not the source of your vibrations, and it could be a clutch balance issue. If the vibrations go away with the clutch pedal depressed, then something in the driveline AFTER the clutch could be the culprit.
And it's the propshaft that spins, not the torque tube. I'm sure you know that though.
If in fact you narrow it down to the clutch and want to try an in-car balance, its' not that difficult to do.
Sounds like clutch engaged, car not moving, but in gear will be the best way?
Is the balancer pinned... if not you could start there, because something should do anyway with SC.
I would do this in Neutral just in case your foot were to slip off the clutch petal by accident. Safety First.
Took car to the track today and high pitch buzz/vibration is still there, now very noticeable 80-85mph. I can now rule out anything rotations in front of the engine so question is, what is next? Torque tube tear down? I've checked what I can under the car when on lift etc to no avail.. Ideas welcome!
Trouble shoot in a logical manner that tries to isolate the probable cause of the vibrations, otherwise you will spend a lot of time and money guessing.
It sounds as though you have an aftermarket flywheel/clutch assembly that I would bet any amount of money that it was not match balanced to the stock FW/PP. That is one possibility alone. Balance weights are sometimes installed in the stock clutch assembly and HB to FINE TUNE total engine balance strictly for NVH considerations.
I will try and outline below what I have done so far:
Car standing still, clutch in (depressed):
RPM 2300-2800-ish range.
Vibration/buzz is active.
Car standing still, clutch out (released):
Car moving, 6th gear:
80-85 mph, droning/buzzing vibration (reminds me of similar symptoms of a u-joint going bad)
Things I have checked so far:
Wheelbearings, 12 o'clock 6 o'clock I can feel no play. I don't feel anything strange while rotating either.
Exhaust mount: checked there is no contact against chassi that causes vibrations.
Front rotating assembly: I was pretty sure this was contributing as I could see a slight wobble to the harmonic balancer prior to replacing but it made no difference. I did replace all rotating assemblies including belts, as it was due for maintenance anyways.
Things left to be considered:
Half shafts, seems like a long shot. But how do you check if suspect?
Torque Tube, I assume only way to check is to tear it down and inspect?
Clutch/flywheel, same thing as above.
Rear diff, how to check? (fluids have been replaced).
Transmission, how to check? (fluids have been replaced).
The tricky thing is that the symptoms are present both standing still and moving, but changes in characteristics as I reach the 80-85 mph zone. I can depress the clutch, and coast in that speed range and still have it drone/vibrate.
When you say you experience a different type of buzzing/drone at 80 to 85 mph, it could also be drone from your Borla Stingers. Could be. Plenty of people have complained about droning at "cruising" speeds.
Plenty of people have done the PP bolt hole washer exercise with good results.
The issue at speed has gotten worse and it comes to mind as similar symptoms when a u-joint goes bad and you get that type of feedback through the chassis. The rpm dependent vibration when standing still could be the exhaust for sure, but the issue at speed is definitely something else contributing.
I'll have to get the car on a lift and start digging as this is still mostly speculations.
I wish something would just blow up so it would be obvious what's going on
