ecm removal on 98 vette
Found these instructions on the web that will help out. Just click the link and it will take you to a pdf document.
C5 PCM REMOVAL
What issues and or DTCs are you seeing??
Just trying to save you cash and time.
Bill
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
I always read my DTCs prior to turning OFF the ignition switch. If you have any messages on the DIC,, PRESS RESET until they are gone!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect.)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, "C" or "H". A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
The headlight issue is seperate from the PCM Comms issue.. It has a stripped plastic driven gear that needs to be replaced.
Once you have read and jot down the codes, CLEAR ALL OF THEM and then see what DTCs come back after a short drive.
Bill
Those will be the important ones.
Bill
Is your EBTCM front OR rear mounted???? Either way, you need to check the ground wire and make sure that its properly grounded and the ground point isnt compromised/corroded/loose etc...
NO COMMS means:
- You dont have all the power going to or out of the module.
OR
-Your module isnt functioning
OR
-The serial communication wire is damaged/not communicating..
This is a picture of a rear differential mounted EBTCM:
If you have a front mount,it will be here:
100% with Bill on the TCS No COMM issue.But I want to ask whether or not you cleared ALL the codes and then took the car for a ride??? It is unclear from your post if you did the clear.....
If you DID clear ALL codes and the LDCM and RDCM codes you listed came back then I suggest that you have a battery related issue going on that COULD be contributing to your symptoms. The battery is either low or the battery cables may not be tight or the battery cables may be corroded.
Have the battery tested and insure it is FULLY charged. The car will start with low voltage at the battery but the C5 electronics will NOT be happy.
Last edited by Scott Luttrell; Jan 9, 2015 at 05:29 PM. Reason: more to add regarding the issue.
Press & HOLD the LOCK & UNLOCK buttons until you hear the horn TOOT. That should take care of that.
Bill
can u give me the instruction on replacing the gear in headlight motor? The fob stopped working. I pulled the battery to check for previous leaks. put it back and my key fob doesn't work. there is no owners manual ,so if u can help with that i'd appreciate it. Thank you so much!! You guys are Badd ****. Sorry for the repeat wasn't sure it took
NO COMMS means:
OR
OR
http://carburetor-manual.com/1998-ch...ad-p-1692.html
Am using an electronic version which I HATE. I can't find the actual connector pin out to help. Will keep looking.
G401 left rear outer frame
G402 right rear inner frame
PS: EBCM ground wire is Black/White and motor is Black.
