Battery Gremlin - '99 FRC
Old Jan 7, 2015 | 08:12 PM
VETTEC599's Avatar
VETTEC599
Default Battery Gremlin - '99 FRC
I don't drive my Vette in the winter - it stays in the garage (not heated, not icy). I fully charge the battery before putting it away. When I try starting it 7 - 10 days later - the battery is dead. I make sure all lights are out; the portable XM is out of the car, both power outlets are unused; the car is in reverse, and both doors are shut tight. I repeat the whole charge/check procedure only to have the same result when I try to start it 7 - 10 days later. Any thoughts and/or suggestions appreciated.
Old Jan 7, 2015 | 08:41 PM
mrlmd's Avatar
mrlmd
Your battery shouldn't die that fast unless maybe you have some unforeseen current draw pulling it down. If you have a multimeter, disconnect the negative ground cable from the battery, and with the one lead of the meter connected to the negative battery terminal and the other lead on the cable, measure the amount of current passing through there. If I remember correctly it should be maybe 20 miliamps. If it's much higher than that, something is draining the battery and then you have to start disconnecting fuse boxes and then fuses to find it. It could be a seat motor, many possibilities.
If you have no excessive draw, then charge up your battery fully and then get it load tested to see if it's any good. If it is, your last choice is to get a trickle charger and leave it on when you don't use the car.
What are you charging the battery with? Is it a regular charger or a "maintainer"? ie, how many amps are you charging with?
I'm sure others will also chime in and give you more insights.
Old Jan 7, 2015 | 08:45 PM
Paul 75 L82's Avatar
Paul 75 L82
How old is the battery, I only get about 14 months on mine.
Old Jan 9, 2015 | 11:23 AM
3boystoys's Avatar
3boystoys
WOW, I have about 8 YEARS on my Redtop so far, I keep it on a battery tender when cars in the garage.
Old Jan 9, 2015 | 09:02 PM
Darrell98's Avatar
Darrell98
Do you leave the battery tender on 24/7 ?
Old Jan 9, 2015 | 09:36 PM
PRO5OHHO's Avatar
PRO5OHHO
My 99 has a gremlin like that too. It's been happening ever since I bought the car 3 months ago. I can let the car sit for a week and the battery is fine, I can let it sit for 1 day and it's dead. Made absolutely no sense. Neither I nor my troubleshooting guy could find anything draw on the battery or anything wrong with the battery itself. So he let me borrow one of his loaner batteries and I ran that for a week and didn't have any battery issues. So I just went ahead and bought a new battery. If that ends up not working out for me I'll find the facepalm emoticon and come back to this thread.
Old Jan 10, 2015 | 09:06 AM
92GA's Avatar
92GA
Oldtimer
My car did the same thing when I bought it. The guy I bought it from used to unhook the battery when he stored it for the winter. Well I didn't and the first time I tried to start it after sitting for a month it was dead, not flat but it wouldn't start. So I charged it up and kept an eye on it. About 3 weeks is all it stay up. I charged it up and had it tested. It was bad. Replaced it and all is good. I do leave it on a tender during winter storage.
Old Jan 10, 2015 | 10:06 AM
3boystoys's Avatar
3boystoys
When It's in the garage it's on the tender but during the driving months I've been known to not have it on the tender for several days.
Old Jan 10, 2015 | 10:58 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
THE SECRET!!!!!!
What is your cars battery sleep current draw AND,,,,, What condition is your battery in?
Does it have proper RESERVE CAPICITY?????
If you have the best battery in the world, it will go dead if the electrical system drawing excessive current. The car was designed to draw 20-25 milliamps.
What is yours drawing???????
Bill
Old Jan 10, 2015 | 02:15 PM
lionelhutz's Avatar
lionelhutz
Yes, test the battery and the sleeping current draw. The car should easily be able to sit 3-4 weeks and still start.
14 months on a battery - yikes. What are you doing to them to kill them so fast? My last cheap one in the C5 was 6 years old and was good until I loaned it to my uncle and he ran it down which killed it.
Old Jan 11, 2015 | 03:31 PM
Catman58's Avatar
Catman58
Originally Posted by Bill Curlee
THE SECRET!!!!!!
Bill
Bill, what is the correct procedure to check this draw? Thanks
Old Jan 11, 2015 | 03:34 PM
Sox-Fan's Avatar
Sox-Fan
8VETTE7 posted this for you up above. Scroll up.
Old Jan 11, 2015 | 04:26 PM
Catman58's Avatar
Catman58
Yes he did, sorry didn't see it
Old Jan 11, 2015 | 05:02 PM
3boystoys's Avatar
3boystoys
Same as any current draw test, amp meter in series with battery.
Old Jan 11, 2015 | 07:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Jan 12, 2015 | 09:59 PM
Catman58's Avatar
Catman58
Thanks Bill
Old Jan 13, 2015 | 12:09 AM
4DRUSH's Avatar
4DRUSH
Check the DIC & dimmer button lights at total darkness.
I happened to stumble upon my 99 FRC lights staying on after sleep mode.
It's a problem with the Instrument circuit board.
I ended up cutting the wiring to those lights (bulbs aren't removable)
Maybe someday I'll get another board & fix the wires or tap into another source
To Battery Gremlin - '99 FRC
