Codes galore help please?
Old Aug 6, 2002 | 06:01 PM
Vinzvette's Avatar
Vinzvette
Default Codes galore help please?
P1515,P1516,P0141,P0410,C1278,U1096,U106 4 thanks for any help!
Old Aug 6, 2002 | 07:34 PM
Vinzvette's Avatar
Vinzvette
Default Re: Codes galore help please? (Vinzvette)
ttt
Old Aug 6, 2002 | 08:07 PM
Jackal's Avatar
Jackal
P1515 - Command vs Actual Throttle Position performance (PCM Module) -A
P1516 - P1516 Command vs Actual Throttle Position performance (TAC Module) -A
P0141 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2-B
P0410 - AIR System-B
C1278 - TCS Temporarily Inhibited by PCM
U1096 - Loss of Communications with IPC
U1064 - Lose of Communications with DCM
Hope this limited info helps.
Old Aug 7, 2002 | 12:04 PM
Chopper Larry's Avatar
Chopper Larry
A friend's '98 recently dumped virtually these same codes; I'm suspecting faulty or corroded wiring around the PCM or BCM area due to a bad battery or A/C drain. Just my idea. Haven't got in there yet.
To Codes galore help please?
