Question about intake mainfold cleaning....
Old Jan 18, 2015 | 04:17 PM
Zealot06's Avatar
Zealot06
you said map sensor... yeah just pop the map sensor out and leave the other piece and you'll be fine
Thanks Neutron. Did just that. Cleaned my IM using a solvent sprayer and cleaning solvent, and followed up with mild detergent & rinse. Got a fair amount of oil residue out so I guess I may want to install a catch can.
Old Jan 18, 2015 | 04:32 PM
StingrayRebel's Avatar
StingrayRebel
you should definitely install a catch can... if you're just putting the car around town I guess it doesn't matter but if you want to add power and do some spirited driving then the oil is not a good thing as it messes with your air/fuel mixture... you might also clean what you can in the head ports... I wouldn't spray anything in the ports, try spraying some brake cleaner on a rag and wipe out what you can
Old Jan 18, 2015 | 10:17 PM
Zealot06's Avatar
Zealot06
Thanks, Neutron. I cleaned out as much as I could from the heads before I reinstalled the IM. Great advice.
