little Help Please! p0300
Old Jan 22, 2015 | 02:24 PM
Kevin Kuse's Avatar
Kevin Kuse
Update: Finally found the cause of the miss! #7 Exhaust lobe on the cam was badly worn! So New Cam & lifter here we come! Thanks for all the Help guys!
Old Jan 22, 2015 | 04:26 PM
3boystoys's Avatar
3boystoys
Might have to pull the engine out to get all the bits out.
Old Jan 22, 2015 | 04:42 PM
enoniam's Avatar
enoniam
I had a lifter go bad and take out a cam lobe on an 03 Avalanche with the 5.3. Replaced cam and all lifters and was able to replace 4 out of 5 cam bearings with the engine in the truck. Engine had 261,000 miles on it at the time - it now has 288,000, and sees up to 10 pounds of boost.
Old Jan 24, 2015 | 12:00 AM
martysauto's Avatar
martysauto
St. Jude Donor '14
Glad to see you found the problem!
