172 - 178 Thermostat
1. By-Pass Throttle Body
2. K&N CAI
3.TI Exhaust
4. Upgraded suspension
The last two things I wanted to get done are:
1. Install lower stat 172
2. Send PCM off to get tuned
With that said I could really tell a big difference in HP .... Probably 30 to 40 Horses increase. So with the last two mods maybe another 12 to 15 HP.
I did fine the information about the weather very helpful, because I am up north (kinda) and I like to drive year round ... Thx everyone for the info.
2. K&N CAI
3.TI Exhaust
throttle bypass= 0 hp gain
K&N= 5 to 8 hp max
Ti exhaust only unsprung weight improvement= 5 hp.
upgraded suspension = 0
Total= 13 HP max.
Lower stat does noting without modifications to the fan settings and only used to give slightly more advance when you tune the car.
HP gain = 0
Years ago when all these add-on's were being introduced, many of my friends would buy the products believed they could go faster. Several trips to the drag strip proved they were not faster but in some cases slower. We even had one who went to the strip one day stock and made a few passes, added a k&N and went slower.
By putting in the 172 T-stat you will get water flowing as it opens but your fans will still not turn on until you reach the 220ish temp they are programmed to. Also, the stock T-stat is set for around 186-189F. I have lowered my fan setting and I run about 205 all day while going down the road and about 225 when autocrossing. HTH
K&N= 5 to 8 hp max
Total= 13 HP max.
HP gain = 0
Understand, he (Evil-Twin) was an engineer on the engine design team.
You can easily find testing that shows aftermarket catback (or over axle) exhausts gaining 8-12RWHP over the factory base system. I doubt the Ti system gains that much though, so there is likely a few HP there. The other modifications add very minimal HP levels.
People will tell you that you need to regularly get the bulk oil temperature (the pan temperature or the temperature displayed by the gauge) over 212* to maintain the health and expected life of the oil. I suggest you look up the GM Oil Life Monitor patents because the OLM quits degrading the oil life at 176*.
K&N= 5 to 8 hp max
Total= 13 HP max.
HP gain = 0
) just get to heaven a couple of fractions of a second sooner.
K&N= 5 to 8 hp max
Total= 13 HP max.
HP gain = 0
Mine are 185* because my (GM @ ASE Master Certified Technician) mechanic keeps it there. just saying
) just get to heaven a couple of fractions of a second sooner.Its called psychosomatic sensation. ( a sensation that your mind tells your body )....
here is an example... tenured members might remember this:
The fatal " WOW " factor post.
You never want to say " WOW " after spending the money and time putting on a mod, unless you fully vet it out...
Granatelli Throttle Body: members bought this and claimed 20 HP gain.
members posted " Wow " seems like more than 20 HP.. etc. etc.
other members bought into this hype.. many were sold, then people started to dyno the difference and soon everyone realized that this expensive mod took 15 hp off the base line... soon others did the same thing and all found the Granatelli throttle body was a bad idea.. yet lots of member initially posted " Wow "..... to further this story.. Granatelli manufacturing ( a supporting vendor at the time )came into that thread and said their was a fault in the original design.. offered a trade in, money back, or trade up. etc... this was 7 or 8 years ago... My point here is that all the member who bought the defective part, initially .. said " WOW ".. what an improvement.. the reason ???? psychosomatic sensation ( they believed, in their head , that because they spent the money, that it would be an improvement because it was advertised to be a 20 HP gain...seat of the pants dyno is a poor judge of actual advantage.
The End
Bill aka ET
Just like the throttle body bypass.. another useless waste of time and money.. be it the 5 dollar version or the 15 dollar version... vendors will sell you anything they can make a buck on...Corvette owners are , for the most part very gullible customers. Vendors have to put their kids through college too and their justification is.. they didn't put a gun to anyone's head to buy it.
ET's thought for the day...
The End
Bill aka ET
Unless you think I bought into any hype here.. I've never done that... I always tell people to be careful about hype and who they listen too... I have not made one mistake, because I do enough research before I get involved with anything. If I say " Wow" about anything its because.. it was a worth while modification. BTW I've never said Wow about anything... although I have installed a lot of worth while modification.. Not one single day of trouble or burden over any Corvette I've owned. Normal maintenance and repairs are not a burden, everyone has things to fix or repair. I've been fortunate that I've had nothing but typical low level repairs.. Anything that need maintenance Ive been able to do that for 50 years, I don't have to depend on anyone to do anything.
