Evening everyone, I am having the hardest time resetting the tpms on my 02 coupe. I have followed the youtube vid on how to do it with a magnet but I am having no luck. I have also tried two different size circular magnets also. Is there another way other than taking it to tire shop? Thank you in advance.
I tried syncing some sensors before they were installed. The sensor had to be woken up before the magnet would work. I used a flat magnet (head positioning magnet from inside an old computer disk drive - VERY strong).
I use a magnet parts dish and just rest it against the tire above the stem, sometimes it takes a few seconds but hasn't failed me yet. Just did it today after installing my stock tire and rims again.
I use the same thing, parts dish magnet. Drive it for a few minutes, and then program. hold the magnet on for several seconds, it works for me
I had used a small magnet I bought from Radio Shack on 5 or 6 sets of wheels. On some I found it worked better in the barrel of the wheel like 8VETTE7 suggested.
This year I had a another set of wheels with Schrader sensors ('01-'04 style) that I could not get to train. I could get the horn to beep once in a while on the LF and once on the RF, but could never get the rear to beep at all. The sensors were only about a year old. I tried several different magnets and no luck.
I bought a 2" x 1" x 0.5" Neodymium N52 magnet. I think this is supposed to be the strongest type magnet and that size would fit up to the wheel easily, yet big enough to provide some strength. It worked on all four wheels the first time I tried it.
Up till now i had good success with lesser magnets and did not understand that so many people had problems. Now I have had problems and I think some sensors are easier to train than others. I am just glad the very strong magnet worked.
thanks everyone. I am going to just try to find the strongest magnet. I have a pulling magnet that is rated for 60 lbs but still no luck. I will give the Neodymium N52 magnet a try tho
