Ls6 Components
Old Aug 7, 2002 | 09:16 PM
ROD BROWN's Avatar
ROD BROWN
Default Ls6 Components
I have a chance to pick up Z06 heads,cam,and intake manifold.Would this combo give me a significant increase in performance?I don't wan't to waste my time if it won't really make much differance. :chevy :chevy :flag :chevy :chevy
[Modified by ROD BROWN, 5:19 PM 8/7/2002]
Old Aug 7, 2002 | 09:43 PM
Miles in Michigan's Avatar
Miles in Michigan
Default Re: Ls6 Components (ROD BROWN)
2001 or 2002 Z06 parts? If 2001, then you should get 330-340rwhp, which is what 2001 Z06's dyno. If 2002, you should get close to 355-365, which is what I think 2002 Z06's dyno. You won't quite reach those numbers, because the Z06 also has different exhaust manifolds and cat-back exhaust, but I'd be surprised if that amounted to more than a 10hp difference.
You'd also need your car reprogrammed, at least the rev-limiter raised. A full LS1Edit dyno tune will cost about $500, but will get the most HP out of the mechanical parts.
IMO, because of the labor costs for install and tuning (probably $2000), I wouldn't recommend the stock LS6 parts. Definately not the 2001 stuff, and most likely not the 2002 stuff, unless you are basically getting it for free and know someone who will do the install cheap.
[Modified by Miles in Michigan, 7:55 PM 8/7/2002]
Old Aug 7, 2002 | 10:00 PM
Miles in Michigan
Default Re: Ls6 Components (Miles in Michigan)
A cam, springs, titanium retainers, chrome-moly pushrods, and timing chain will cost about $900. Add about $500-$800 for install. Long tube headers will be about $1000, maybe $300 for install. The intake manifold is $420, maybe $100 to install (or install yourself, I hear it's easy). An underdrive pulley is $250. Tuning is $500. That's about $4000, and should get you a bit over 380rwhp (with a 220/220 .560/.560 or greater cam), maybe as much as 400rwhp (with a 224/224 or larger).
With 2002 LS6 heads, cam, and intake, you'll pay about $1500 for install (a lot more than installing just a cam). You'll still want tuning for $500 and the pulley for $250. Personally I wouldn't do it without doing LT headers, for $1000+$300 install. So that is $3500 plus whatever you are paying for the LS6 heads, cam, and intake manifold. With the headers you could get 370+ rwhp, possibly a bit above 380rwhp, so you'll almost equal the power for an aftermarket cam and stock heads, but it'll cost more (unless you get the Z06 stuff for less than $500).
Old Aug 7, 2002 | 10:29 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Rod knows where to go where the labor won't be nearly that much. :D
Old Aug 7, 2002 | 11:25 PM
Miles in Michigan
Default Re: Ls6 Components (Andy@AandACorvette)
Rod, you have to have Andy do it. :yesnod: I hear you get fast work, great prices, a good meal, and a place to crash for the night. :lol:
If you're sure you don't want a more radical cam (which makes more power but has a rougher idle, might not pass emissions, etc) and it's an 02 Z06 the parts are coming off of, then with Andy doing the labor it's not a bad deal.
You should know that it's not gonna break 400rwhp like an aftermarket heads+cam package will, although for the positives it won't idle rough, or be nearly as hard on the valve train.
To Ls6 Components
