Electric fans
Old Jan 27, 2015 | 10:19 PM
Spare Time Toy's Avatar
Spare Time Toy
Default Electric fans
What temps do the fans kick on. Coming home today I got to 230 before one of them came on. Shouldn't one kick in before then.
Old Jan 27, 2015 | 11:12 PM
StingrayRebel's Avatar
StingrayRebel
depends on what's in your tune, they can be commanded to turn on and off at any temperature... if you have hptuners you can check
Old Jan 28, 2015 | 08:24 AM
Spare Time Toy
Originally Posted by 8VETTE7
Factory set turn on temp for fans at low speed is 226. BOTH fans run in either low speed mode or high speed mode which starts if the coolant temp reaches 235 degrees. If you are running the AC then the fans come on in low speed mode at 185 degrees. High speed mode with AC running is still 235. Be aware that the PCM commands fans off when the vehicle speed exceeds 35MPH. Apparently GM felt that air flow through the radiator was better at 35 and faster than running the fans.
If you had only one fan running then there is a problem.
As mentioned by neutron82 the turn on temp for both low and high speed operation can be programmed to values different than factory settings.
I guess its working as it should. I have just never watched temps that closley. I just thought I smelled antifreeze so I went on high alert.
Old Jan 30, 2015 | 08:32 AM
joe Villarreal's Avatar
joe Villarreal
Default temp
great answers
Old Jan 31, 2015 | 11:46 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
8VETTE7 has this issue cover with good clear input...
One other thing I will add is a C5 is a bottom feeder. Its like a vacuum cleaner sucking in air and also debris . How you keep your engine cool is by allowing both the radiator and the AC condenser, which sits in front of the radiator to be a clean as possible. Heat transfer is a product of air flow through both of these components. AS small as the radiator is, and its design restraints, it should be cleaned once a year.
Having a free flowing condenser and radiator will go a long way in keeping your engine in the " sweet spot " for coolant and oil temperature.
Bill aka ET
To Electric fans
