99 needs mill
Old Feb 1, 2015 | 11:47 AM
SaxyVette's Avatar
SaxyVette
Default 99 needs mill
My base '99's ready for a new motor..what's better for keeping costs to a minimum, would you rebuild or simply get a fresh crate motor ?
Old Feb 1, 2015 | 01:12 PM
dirtrider1219's Avatar
dirtrider1219
Can't you get an ls6 crate motor for 3200 somewhere?
Old Feb 1, 2015 | 06:34 PM
SaxyVette's Avatar
SaxyVette
Originally Posted by 8VETTE7
Here is an article worth reading that may provide some food for thought:
http://blog.chevroletperformancepart...formance-parts
good info.. I don't know the best source for a motor locally in town(Las Vegas)..I need to do some homework. Then I'll need a good shop to do the switch.
Old Feb 4, 2015 | 09:01 AM
nullpointer's Avatar
nullpointer
Two options that come to mind
  1. Junk yard
  2. Rebuild
The Junkyard may have some LS1's in other models that you can pull, freshen up some gaskets and let her eat.
Rebuilding the short block is another option if you have a machine shop that does quality work in your area. Too bad I am on the east coast, I'd help you yank the motor out and save some $$$.
Old Feb 4, 2015 | 09:12 AM
92GA's Avatar
92GA
Oldtimer
You can have the original engine rebuilt for about 1/2 the cost of a crate engine. I would stay away from putting in an iron block if I were you. I'd look on the parts for sale here and see if you could pick up a set of low mileage heads that someone has for sale and the rebuild the stock block.
Old Feb 4, 2015 | 10:14 AM
chaase's Avatar
chaase
St. Jude Donor '12
I would rebuild with performance parts. I am curious why your '99 is ready for a new engine. Did something break?
Old Feb 4, 2015 | 02:26 PM
SaxyVette's Avatar
SaxyVette
My heads look pretty fresh, block's got high mi..I'm checking into a shortblock as well. Just not sure which way i'll go yet. Realizing a full crate engine may be out of the equation (too much $$$). I have scored a respected local mech that will do the switch for a great price.
The orig prob was the cam ate one lifter, we replaced just the one lifter. It ran good for an hour then started making worse noise than the first time.
To 99 needs mill
