WIRING Harness Guru's ?
Old Feb 2, 2015 | 11:08 PM
junk c5's Avatar
junk c5
Default WIRING Harness Guru's ?
I've got a 1999 A4 vert and it has minor fire damage to both o2 sensor harnesses due to a small fire which occurred from oil getting onto the headers. I haven't found a complete front main harness from the exact year and specific model to purchase one and I'm currently looking for an experienced wiring guru to repair the harness .
Here's the question : What years and models will work on my vehicle ? The complete harness contains the wiring harnesses for the injectors, MAP, Mass air flow, AIT, alt., starter wiring, and a few more sensor harnesses.
Any help or direction would be great. Thx
Old Feb 2, 2015 | 11:16 PM
junk c5's Avatar
junk c5
[URL=http://s198.photobucket.com/user/stockturbocoupe/media/Mobile%20Uploads/image_zpsnvbgbzh6.jpg.html][/U
Old Feb 2, 2015 | 11:31 PM
junk c5's Avatar
junk c5
Old Feb 3, 2015 | 08:27 AM
dadaroo's Avatar
dadaroo
If it were me, I would just splice in new wiring starting from where you have good undamaged wiring in the harness. Would just need new connectors and looks like one lug. I would use solder and heat shrink tubing to make it as good as new.
I can provide the wiring info/colors and pin outs for the connectors. Otherwise, if you want a replacement harness contact Marc at VetteNuts.com.
Old Feb 3, 2015 | 10:10 AM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We may can help you with a donor harness. I can cut you off what you need to replace. I can see from the pics the starter and 02. What else got burned?
Old Feb 3, 2015 | 11:00 AM
junk c5's Avatar
junk c5
Everything else is in good shape. There was a small fire on the headers due to a pushed valve cover gasket as a result of burning a piston. If I didn't have a fire extinguisher the car would have burnt to the ground.....
Old Feb 3, 2015 | 11:02 AM
dadaroo's Avatar
dadaroo
I would work with Marc. If you need help with the splicing I can walk you through that over the phone.
Old Feb 3, 2015 | 11:14 AM
junk c5's Avatar
junk c5
Awesome, thx. I'm gonna try to sub this project out. The last thing I need is an electrical gremlin. The cars going thru a complete makeover and I can't have any unnecessary or avoidable issues.
Old Feb 3, 2015 | 01:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Whether you Sub it out or do it your self,,, If you don't have the correct connectors and gage wire, it will never work correctly.
If it were ME,,, I would tap Marc for the correct harness or even a partial harness.
If you have someone else repair it, how will you know it done with all the correct stuff?
Just provide them the harness or part harness with the correct wires and parts and you will have a better chance of a proper repair.
BC
Old Feb 3, 2015 | 01:25 PM
junk c5's Avatar
junk c5
BC
That seems to be the general consensus. I spoke with Marc and I'm going to ship it his way tomorrow for his services.
Old Feb 3, 2015 | 04:43 PM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We will get you back on the road with an all OEM harness.
Old Feb 3, 2015 | 06:23 PM
LoneStarFRC's Avatar
LoneStarFRC
You da man MR!
Old Feb 4, 2015 | 06:42 AM
dadaroo's Avatar
dadaroo
Roger on that.
Old Feb 6, 2015 | 09:19 AM
4DRUSH's Avatar
4DRUSH
With that much damage, probably melted a hole in the firewall (been there) you should pull the motor to check everything
Old Feb 6, 2015 | 09:36 AM
dadaroo's Avatar
dadaroo
I would not pull the motor just to look. I would get a boroscope camera. To find a hole in the firewall all you need is a simple one which are very inexpensive.
You can do a search on Inspection Camera.
Old Feb 6, 2015 | 02:47 PM
junk c5's Avatar
junk c5
Motor is already out. Waiting for its replacement. Should be done next week.
Old Feb 6, 2015 | 02:57 PM
LoneStarFRC
These guys are one of the better sources for new, correctly color-coded pigtail GM connectors.
https://www.eficonnection.com/
Look at the left side menu under "Harnesses and Connectors" and click on "Connector Pigtails".
HTH
To WIRING Harness Guru's ?
