Headlight Help
Old Feb 5, 2015 | 06:29 PM
Daddyrama31's Avatar
Daddyrama31
Default Headlight Help
Both headlights go up and down just fine. However, the passenger light makes a strange sound when start up or when turning off. Sounds last around 10 seconds or so. Anyone have an idea on how to fix?
Old Feb 5, 2015 | 06:54 PM
frsr06's Avatar
frsr06
Sounds like its time to replace the plastic gear in the headlight worm/worm gear drive. Search on C5 headlight gear replacement and you'll find several good sources for a brass gear to replace the plastic/nylon gear. Takes about an hour to perform not counting the time for glue to dry. I just finished both lights - not a big deal. Brass gears are about $45 each. I'd do both at the same time (one at a time) just to get the issue behind you.
Old Feb 6, 2015 | 01:54 AM
Daddyrama31
Thanks bro. Saw a video on YouTube of a bad gear, Same sound!!
To Headlight Help
