c5 1999 fob problems
Old Feb 19, 2015 | 05:03 PM
phillyphan0879's Avatar
phillyphan0879
Default c5 1999 fob problems
i bought a c5 a week ago, put a new battery in the fob,reprogrammed it and it worked for a couple days. stopped working battery is still good. reprogrammed again and it still isnt working, programming said it synced. thanks
Old Feb 19, 2015 | 05:07 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
does it rattle when you shake it? mine does...internal crap came apart
Old Feb 19, 2015 | 08:48 PM
65GGvert's Avatar
65GGvert
99 is supposed to rattle when you shake it, that's how the passive signal is sent. Read 8vette7's link and you can fix it from losing sync for free.
Old Feb 20, 2015 | 01:06 AM
phillyphan0879
i read through that thread earlier but it looks like all the solder is good
Old Feb 20, 2015 | 06:02 AM
65GGvert's Avatar
65GGvert
You can't tell by looking. It doesn't work now, what could you hurt by resoldering? A new fob for your model is around $90 if you can find one. You can use a 2000 fob, but it won't have passive mode. You cannot use a 2001-04 fob unless you upgrade the rfa and tpms also.
Old Feb 20, 2015 | 02:52 PM
phillyphan0879
yea ill probably end up doing that, i do need another remote and key though since the car only came with one. it started working again after i reprogrammed it 2 more times.
Old Dec 4, 2018 | 12:23 AM
nuts105's Avatar
nuts105
Huge discovery: throwing away the passive fob and replacing it with the non-passive cheaper fob = no more excessive battery drain!!
For years I had to replace the batteries every couple of years, and car would go limp if my daily commute was less than 10 minutes. Couldn't quite see an aporoach to the problem as I don't believe in grounding issues causing parasitic drain, and never successfully put anything in parallel to measure current with a meter (they just not built for initial spike on connection).
After my fob finally was so worn out and too weak for goid use, I plonked down $100 to get the overpriced fob replacement. Within a week, battery fully recovered and car roars like a beast when starting. Unbelievable.
So: the car has been about 50 feet from where I live. No way the fob works at this distance. So it must be the mini-earthquakes in California that we get 24-7 but you can't feel that wake the fob up, AND it somehow manages to at least wake up the vette, even though it's not strong enough to lock-unlock at that distance.
It baffles me but it 100% was the cause of the battery drain.
To c5 1999 fob problems
