start up
Old Feb 20, 2015 | 05:36 PM
pops4now's Avatar
pops4now
3rd Gear
Default start up
Can someone help before I have to take the car to the shop $$$$.
Most every time I start my 03 vette the computer tells me to pull the key and wait 10 seconds and re-start the car. Is this something simple or must I take the car to the shop for a costly analysis ?
Old Feb 20, 2015 | 05:41 PM
grantv's Avatar
grantv
Do a search, many posts on this common problem. Easy fixes...
Old Feb 21, 2015 | 10:37 AM
pops4now's Avatar
pops4now
3rd Gear
Originally Posted by 8VETTE7
DO NOT TAKE YOUR CAR TO A DEALER FOR THIS ISSUE!!!!!!!
Is this a manual transmission car?????
If you do not "pull the key...." can you drive the car or does it stall immediately?????
What happens when you try to turn the wheel with no key in the ignition?? With effort you can turn the wheel at least 1/2 a turn?? Wheel is locked and cannot be turned??
When was the last time you had the battery tested???
Is the carpet in the passenger foot well wet??
Suggest that you google "Complianceparts" and read about their LMC5. You will need to order and install one to permanently eliminate the C5 Column Lock symptoms......
I thank you very, very much for the info. If the weather ever gets warmer I will start checking for the suggested problem/solution.
Old Feb 21, 2015 | 07:01 PM
pops4now's Avatar
pops4now
3rd Gear
Default starting up 10 second delay
I'm sorry for only answering half of the questions, I am new at this your patience is appreciated.
Car is a 6 speed manual trans.
If you try to drive the car it will only go about 6 feet or maybe 10 mph.
I put a new battery in about 3 months ago.
The passenger side foot well is dry. I also checked under the hood all around the battery and it is dry and the steering wheel is locked it will not move till you try to start the car.
To start up
