EXHAUST LEAK?
Old Aug 9, 2002 | 12:54 PM
THENAKEDi's Avatar
THENAKEDi
Default EXHAUST LEAK?
Yesterday, while driving next to a wall on the driver's side of my car, I heard an odd ticking noise, which sounded like it was coming from the exhaust system. It pretty much sounds OK in regular driving, but when I am next to a wall or car, I can hear the ticking noise at the low end of the power band. Is this an exhaust leak? What is the process for checking? Is it a simple visual inspection? Any thoughts are appreciated! Thanks in advance.
Old Aug 9, 2002 | 03:23 PM
Turbo5's Avatar
Turbo5
Default Re: EXHAUST LEAK? (THENAKEDi)
The welds in the flanges that hold the exhaust system together are most likely bad. They have a real problem getting the ehaust to stay welded.
Good luck. :rolleyes:
Old Aug 10, 2002 | 05:45 AM
CrazyMagMan's Avatar
CrazyMagMan
St. Jude Donor '05
Default Re: EXHAUST LEAK? (Turbo5)
That's probably the problem with mine too........ugh..... :rolleyes:
Old Aug 10, 2002 | 10:02 AM
Xssesive's Avatar
Xssesive
You can get underneath car and look for black stains around flanges, you usually can find them, but as stated aove you made just need to have the flanges rewelded. :yesnod:
Old Aug 10, 2002 | 05:35 PM
THENAKEDi's Avatar
THENAKEDi
Thanks guys!
Old Aug 11, 2002 | 03:01 AM
rhawki's Avatar
rhawki
I had an exhaust leak that the dealer took care of per TSB on shimming the exhaust with some washers. It pretty much took care of it, but i can still hear it with the windows up and the radio off.
As previously mentioned, there were also problems with the exhaust flanges on the driver side only.
-Rich
To EXHAUST LEAK?
