97-98 fuel system conversion
Old Feb 22, 2015 | 10:51 AM
chris308's Avatar
chris308
Default 97-98 fuel system conversion
I want to swap my 99 returnless fuel system over to a 97-98 one.
Does anyone who has done the conversion have a parts list?
Old Feb 23, 2015 | 09:19 AM
dadaroo's Avatar
dadaroo
I am not aware of any difference in the design except in 1999 the passenger fuel sender was changed and is different (now 3 wires instead of 4). If you want a 97-98 design then you are into wiring changes and PCM issues.
Some engine delivery fuel is still returned to the passenger tank and a jet pump then transfers fuel to the driver side. The design of all C5's deplete the passenger tank fist and then the driver side.
Fuel Senders
Old Feb 23, 2015 | 09:41 AM
dadaroo's Avatar
dadaroo
Forgot to mention that there are differences in where the FPR is located from 99 to 97-98 and that you may have a pulse damper. Not sure when they went to a pulse damper on the fuel rail. They should not relate to whether fuel is returned to the passenger tank.
Old Feb 23, 2015 | 09:57 AM
chris308's Avatar
chris308
Thanks for the posts,
I was interested in doing the swap of the 98 rails and feed/return lines with the reg and filter separate for my supercharger application. It is said to swap to a return style setup you can run more hp.
I may just run all new stuff since i'll be switching to E85 anyways...
Old Feb 23, 2015 | 10:03 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
I think this is a complete list of what I used from Summit.
AEI-13109 FUEL REGULATOR 1 1Z4758400159036939
AEI-15606 FITTING 2 1Z4758400159036939
ATM-2174 PRESSURE GAUGE BLACK DIAL 1 1Z4758400159036939
EAR-9893046ERL FLARE EXPANDER 4-6AN 1 1Z4758400159036939
MRF-MP-3071 #6 AN PLUG W/ 1/8" PIPE PORT 1 1Z4758400159036939
RUS-640930 FUEL RAIL ADAPTER FITting 1 1Z4758400159036939
SUM-220687 -06 90 HOSE END SWIVEL 1 1Z4758400159036939
SUM-220690 6AN HOSE END STRAIGHT 1 1Z4758400159036939
SUM-230615 S.S. HOSE -6 15FT 1 1Z4758400159036939
EAR-915106ERL -6 FEMALE SWIVEL 1 1Z045WV80159796700
Plus a 97 fuel filter. PM me if you want to talk on particulars
Old Feb 23, 2015 | 10:15 AM
chris308's Avatar
chris308
Awesome! Thanks a bunch, I will def be contacting you Sir. Thanks again...
Old Feb 23, 2015 | 10:58 AM
dadaroo's Avatar
dadaroo
Interesting. I'm curious how the change affects flow and/or pressure but you don't need to waste your time bringing me up to speed. I am just curious as engineers are.
If you have a link or write up on it I would be interested in that.
Mr. Sam
Old Feb 25, 2015 | 10:07 AM
jackthelad's Avatar
jackthelad
Fyi, 97/98's also used bigger injectors. I suspect that is why they can pick up more bhp with a decent intake.
To 97-98 fuel system conversion
