Oil Temp Low
Old Feb 22, 2015 | 06:29 PM
Big Al's Avatar
Big Al
Default Oil Temp Low
Was running the car today. It has not been driven lately with the Winter weather here in Ohio. All seemed normal. No codes or anything. It is 34 degrees in the garage. So moving through the DIC, the Oil Temp says Low.
Oil temp low. Not Oil Pressure nor Oil Level. Oil Pressure is around 40. Level is fine. Warmed car up until Tstat opened. Water temp was 200.
Car is 1999 Coupe 6 speed with 77,xxx miles.
Oil temp sensor is in filter housing if I recall.
Any ideas? How could I check the sensor?
Old Feb 22, 2015 | 06:47 PM
c4cruiser's Avatar
c4cruiser
If there was no numeric oil temp value displayed, the chances are that either the wire connector has broken/fallen off or the sensor is bad. They aren't terribly expensive; Rockauto has them for $16 and change. AC Delco p/n 2134333 Also try Amazon or your local parts store.
Old Feb 22, 2015 | 10:09 PM
dbgoodwin's Avatar
dbgoodwin
Your car is fine. When the temp is really low the oil temp just says "oil temp low" instead of a numeric reading. For some reason the computer never resets itself until the car has been off for around an hour. Confused me the first time too.
Old Feb 22, 2015 | 10:55 PM
corvette77's Avatar
corvette77
Same thing happened to me earlier this year on my way to work. When I left, I made sure to check the DIC to see if the temp was reading, and it was back to normal.
Old Feb 26, 2015 | 07:40 AM
dcandel's Avatar
dcandel
Oldtimer
Same thing here, "low oil temp" See my post from earlier this week.
Old Feb 26, 2015 | 07:42 AM
dcandel's Avatar
dcandel
Oldtimer
Tuesday of this week was the first time I ever encountered this with mine also.
Old Feb 26, 2015 | 09:25 AM
LoneStarFRC's Avatar
LoneStarFRC
The permanent repair for this is move South.
Old Feb 26, 2015 | 11:12 AM
dbgoodwin's Avatar
dbgoodwin
Hahahah I may have to try this once I'm through school!
To Oil Temp Low
