lowering/removing bolts
Old Aug 9, 2002 | 02:02 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default lowering/removing bolts
I lowered my car about 2 weeks ago and I am not happy with the way my fronts sits. In the back I can fit 2 fingers in between the tire and the fender. I want the front to sit like the back. Can I get by with just cutting the bushing 2/3 or sgould I remove the bolts. If I need to remove the bolts does that cause any long term damage? Thanks, Kaley
Old Aug 9, 2002 | 03:06 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: lowering/removing bolts (2C5only21)
Just cut the bushing if you want to get it low. You will get it as low as you need it. :cheers:
Old Aug 9, 2002 | 06:21 PM
0Kaley@DragonRace
Supporting Vendor
Default Re: lowering/removing bolts (racer44)
So removing the bolts is not necessary?
Old Aug 9, 2002 | 06:26 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
to cut the bushing you will need to remove the bolt :cheers:
Old Aug 9, 2002 | 06:30 PM
Patches's Avatar
Patches
Default Re: lowering/removing bolts (Mean Green 2000)
And here's how you do that, pics and all! It's for a Z06 but works on any C5.
https://www.corvetteforum.com/techti...D=90&TopicID=1
:cheers:
[Modified by Patches, 5:30 PM 8/9/2002]
0Kaley@DragonRace
Supporting Vendor
I know I would have to remove the bolts to cut the bushings but I have seen guys remove them completly to lower their car further. Yes I did turn them as far as they would go. The car did lower about an inch but the back is sitting lower then the front. That might be because I used longer bolts. I like how it sits in the back and would like the front to sit the same.Thanks, Kaley
Old Aug 9, 2002 | 09:42 PM
Racer's Avatar
St. Jude Donor '11
I knew what you meant. :D Here is my car with the front cut and the back lowered with longer bolts. It is a great look! :cool:
...and don't ask about the exhaust, that was done by magic! :rolleyes: :D :cheers:
Old Aug 9, 2002 | 10:11 PM
Patches's Avatar
Patches
This is like the C:cool::cool:LEST looking Z ever. Can I get an AMEN??!!
:cheers: :smash:
Old Aug 10, 2002 | 03:55 AM
NastyC5's Avatar
NastyC5
I took my front bolts out :D
Old Aug 10, 2002 | 04:31 AM
0Kaley@DragonRace
Supporting Vendor
Default Re: lowering/removing bolts (NastyC5)
You both have sweet looking cars. I love the stance on both of them. How harsh is the ride if you take the bolts out completly? Wouldn't it cause long term damage by having the leaf spring just resting there? Nasty, what size rims are you using in the front? They look bigger then the stock 17's. Thanks, Kaley
Old Aug 10, 2002 | 05:45 AM
NastyC5's Avatar
NastyC5
Kaley I have 19" fronts with 275-30-19 tires. I have had the bolts out for a year with no problems. I have lowered a lot of vettes. Most of the time I leave 1/3 of the bushing on there cars. If you were local I would be glad to help :cheers:
Old Aug 10, 2002 | 10:29 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Nasty:Your car looks SWEET!!!!!!!!Are those 19/20???I'm thinking of going that combo!!!!Now that I found 345/20"s!!!!Your car looks awesome.
Old Aug 11, 2002 | 02:16 AM
NastyC5's Avatar
NastyC5
Default Re: lowering/removing bolts (Slammed Vette)
Slammed Vette they are 19/20's :yesnod: I am only running 285-30-20's since my car isn't tubbed :( 345's would look awesome.
Old Aug 11, 2002 | 05:14 AM
0Kaley@DragonRace
Supporting Vendor
Okay guys I just finished cutting the bushing on my front end. It looks so awesome. The front and back look the same now so my car doesn't appear to be driving up hill. Thanks for helping me with my decision. I would post pics but I have no clue how.
To lowering/removing bolts
