Quick wheel sensor question, need to know ASAP
Old Aug 10, 2002 | 12:27 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Quick wheel sensor question, need to know ASAP
Does a 99 FRC have wheel sensors and are they the same as a 97? I fugured it was faster to ask here. I'm doing a headsa nd cam on a 99 FRC and we're going to swap wheels. It just dawned on me about the sensors. It would be a whole lot easier if they could be swapped out also. I was just hoping someone would have an answer before I left for the shop. Thanks
Old Aug 10, 2002 | 12:34 PM
55SUX's Avatar
55SUX
Default Re: Quick wheel sensor question, need to know ASAP (Andy@AandACorvette)
Yes and Yes.
Old Aug 10, 2002 | 01:34 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Quick wheel sensor question, need to know ASAP (55SUX)
They are the same dude, I had this conversation with John@ CCW before.
Old Aug 10, 2002 | 06:30 PM
tscales's Avatar
tscales
St. Jude Donor '07
Default Re: Quick wheel sensor question, need to know ASAP (Shinobi'sZ)
To be a little more specific 97=98=99=00 and then 01=02=03
The change was with the 01 model.
Tom
Old Aug 11, 2002 | 12:55 PM
Andy@A&ACorvette
Default Re: Quick wheel sensor question, need to know ASAP (tscales)
Great. Saved me the hassle of mounting and dismounting 8 tires!
Old Aug 13, 2002 | 11:47 AM
ITSBILL's Avatar
ITSBILL
Quick question.... is it difficult to replace the tire pressure sensor? Are there any manuals on this....
Thanks,
99 6spd :eek:
Old Aug 13, 2002 | 12:23 PM
chrislee2's Avatar
chrislee2
Cruise-In II Veteran
Cruise-In V Veteran
Default Re: Quick wheel sensor question, need to know ASAP (ITSBILL)
Thanks,
99 6spd :eek:
Not at all except that you must remove the tire to get at them ;)
The sensor is also the valve stem and has a nut that holds it on the rim.
Old Aug 13, 2002 | 04:34 PM
RCswish's Avatar
RCswish
Default Re: Quick wheel sensor question, need to know ASAP (chrislee2)
Ok another quick question.....Once the wheels are swapped, how do you re-set the sensors? :confused:
Old Aug 13, 2002 | 05:36 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Quick wheel sensor question, need to know ASAP (RCswish)
Look in the Tech Tips section, if I remember right you turn the key on, clear your dic, press reset for 5 seconds, go to tire sensor relearn mode and then use a magnet over each sensor location on the wheels, the horn will honk at the end of the sequece, you must do this for each wheel. The dic will tell you which tire to start with first.
Old Aug 13, 2002 | 08:16 PM
Bill Reid's Avatar
Bill Reid
:yesnod:
:cheers:
To Quick wheel sensor question, need to know ASAP
