I put in a whole new ac delco pump assembly with a Walbro 450 (had an issue with the old filter housing not sealing on the pump and was loosing pressure). Now on the new one the pressure is good at idle, 61psi, but drops off immediately when the car is off. I dont see any leaks. When I blow into the line coming off the top of the pump I cant hear any leaks with the pump removed from the tank. Im gonna pull the pump out of the tank again. Am I missing something here? Racetronix stated the pump does have a check valve.
Id like to mention that with the old pump, it did hold pressure very well with the key off. It still would have 40psi when left overnight. The problem with the filter housing began about 2 weeks after the 450 install.
