Key fobs not working
Try this:Press and HOLD the LOCK & UNLOCK buttons down at the same time. Hold them until the horn BEEPS. That procedure SYNCs the FOBs
If that doesn't work, you will need to RE- Program all your FOBS.
You do that using the IPC DIC.
Here is the procedure for RE- PROGRAMING the FOBS. NOTE!! You have to re-program ALL of your FOBS at the same time!
1. Turn ignition on.
2. Turn radio off.
3. Press Driver Information Center(DIC) RESET button to clear all messages.
4. Press OPTIONS button on DIC until display is blank.
5. Press and hold RESET button for 3 seconds.
6. Press OPTIONS button until FOB TRAINING is displayed.
7. Press RESET button to begin programming sequence.
8. Simultaneously press and hold LOCK and UNLOCK buttons on first remote for 13 seconds. Message will appear when remote is programmed. Repeat this step for additional remotes. Again,, You have to program ALL your FOBs during this session or the ones that you didn't program will not work.
9. Turn ignition off and remove keys from ignition.
10. Test remotes.
You will find the Tire Pressure Monitor training sequence in this same screen.
Hope this helps
Bill
2. Turn radio off.
10. Test remotes.
Hope this helps
Bill
lmc5 in properly.. Bruce
Make SURE all the wires in the female connectors are locked in place.
Bill
