My check engine light came on 2 days ago, and the car keeps giving me these codes:
P0332H - P0332 Knock Sensor (KS) Circuit Rear -B
U1096H - U1096 Loss of Communications with IPC
U1064H - U1016 Loss of Communication with PCM
U1064H - U1064 Lose of Communications with DCM
I've cleared the codes twice, and each time they return. Any help on what todo would be appreciated
I am not sure about the U codes but the P0332 h is what happend on my 99 before I sold it. I kept resetting it also and it just came back. Also your car will go into a open loop mode causing excess power loss.
I took it to the dealer under the extended warranty the problem ended up being thet the intake gasket was leaking and causing the car to knock. Shoot me a IM if you want to know more about what happend.
