Caliper paint?
Old Aug 11, 2002 | 03:59 AM
Wide Open Throttle's Avatar
Wide Open Throttle
Default Caliper paint?
I want to paint my calipers red like on the Z06. What type of paint should I use for this and who sells it? I want to get the right stuff. I don't want it to fade or flake off.
Old Aug 11, 2002 | 04:02 AM
FNC80's Avatar
FNC80
St. Jude Donor '03-'04-'05
Default Re: Caliper paint? (Wide Open Throttle)
Foliatec. Just run a search on this! :cheers:
Old Aug 11, 2002 | 04:53 AM
Sihler's Avatar
Sihler
I bought GM Orange-Red Engine Enamel, sprayed it into the cap, and brushed it on. Looks great, and since it was made for the heat of an engine, it should, hopefully, hold up. Bought it at Auto Zone, use a fine sandpaper to take any paint off the corvette lettering.
Old Aug 11, 2002 | 09:17 AM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Foliatec from Nate at Xtreme.
http://forums.corvetteforum.com/zerothread?id=313390
Old Aug 11, 2002 | 09:45 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Default Re: Caliper paint? (FNC80)
:yesnod:
Old Aug 11, 2002 | 11:36 AM
Xssesive's Avatar
Xssesive
Default Re: Caliper paint? (Smoke-N-Shot)
I used the VHT brake caliper paint from Mid America, comes in different colors, I used the red to match car. I masked area off with newpaper and masking tape, applied about 5 coats with 30 minutes in between. Very glossy! :yesnod:
Old Aug 11, 2002 | 02:18 PM
Patches's Avatar
Patches
Check this thread out on my Eradispeed / caliper paint project. :)
http://forums.corvetteforum.com/zerothread?id=328114
I used Foliatec. It looks like they don't put enough in the kit to completely cover your brakes. Funny thing is, I only needed half of what came in the kit and I put two heavy coats on. :cheers:
Old Aug 11, 2002 | 02:22 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Caliper paint? (Patches)
Pour 15 high temp red
To Caliper paint?
