Cheap Air/Fuel recalibrator ?
---------Snip-------------
You are bidding on a Air/Fuel recalibrator which will change your cars air/fuel mixture and lean out the fuel mixture to give you a small horsepower increase. This recalibrator is a small unit that is designed for easy 10 minute installation and doesn't require any special tools. This modification will not void warranty but if you are worried about it, it will uninstall in 2 minutes. This will not set your service engine soon light either. This will not hurt your motor in any way and it will not affect your computer if its trying to retard timing because of detonation .....
----------Snip -----------
It goes on a little further, my question is what could this be that installs in 2 minutes, and could it be worth it? The item # is 1850542678 , I'm not sure about the rules of pasting the link, so you will have to look it up. It seems like a scam to me, but thats why I'm asking.
Kyle
Every Engine responds differently. You need an adjustable MAF Translator at a minimum to adjust the a/f ratio, or a better way is to use LS1Edit.
You first should diagnose your engines a/f ratio before throwing on a one size fits all device.
