coolant temp wires
Old Mar 17, 2015 | 09:37 PM
maxjett's Avatar
maxjett
Default coolant temp wires
I pulled the engine on my 01 am reinstalling and some how I have misplaced the wires to sensor it is a 2 wire sensor anyone know what color the wires are and where they come out of the harness
Old Mar 17, 2015 | 11:51 PM
Wisdom's Avatar
Wisdom
I can't recall the colors (suspect it's simple black and white or purple and white), but they come out of the wiring harness that runs to the alternator - if it's the sensor that's on the block behind the alternator.
Old Mar 18, 2015 | 06:07 AM
maxjett's Avatar
maxjett
Mine is on the passenger side head at the back
Old Mar 18, 2015 | 06:21 AM
maxjett's Avatar
maxjett
Yep it is by the alt thanks so much just have to move it to the other head
Old Mar 18, 2015 | 08:22 AM
dadaroo's Avatar
dadaroo
So you don't need me to pull the 2001 FSM for you?
Old Mar 18, 2015 | 08:48 AM
maxjett's Avatar
maxjett
No sir I just need to move sensor to the other head pull the plug and plug the other head thanks
Old Mar 18, 2015 | 09:08 PM
Wisdom's Avatar
Wisdom
Oreilly Auto Parts sells a connector pigtail, complete with butt splices if you need it for about $6. I had to replace my connector as the wires got pulled out of the connector and were making intermittent contact with the sensor. The computer didn't like that.
To coolant temp wires
