c5 starting problem need help
Old Mar 21, 2015 | 10:08 AM
Marksmen2's Avatar
Marksmen2
7th Gear
Default c5 starting problem need help
When my c5 is cold it will start up no problem but after it warms up even for just a few minutes it will not start but it will start up no problem if I roll start it has anyone had this issue it's an 02 six speed base model
Old Mar 21, 2015 | 11:25 AM
dadaroo's Avatar
dadaroo
What do you mean by no start. When warm/hot will it crank? Makes a difference in diagnostics.
Old Mar 21, 2015 | 11:47 AM
Marksmen2's Avatar
Marksmen2
7th Gear
It will not crank over with the starter when warm but even if it is warm I can push start it with no problem
Old Mar 21, 2015 | 07:27 PM
73Corvette's Avatar
73Corvette
No clicking, just won't crank? Have you had someone tap the starter while trying to crank, when hot? Could be a bad solenoid/starter.
Old Mar 21, 2015 | 08:48 PM
4DRUSH's Avatar
4DRUSH
Yep
Old Mar 22, 2015 | 06:42 AM
dadaroo's Avatar
dadaroo
Time to replace the starter. Could be the solenoid or the starter motor. Just replace them both. When you normally buy a starter it has the solenoid.
What happens is when the starter gets hot (it's attached to the motor and by the exhaust) the internal resistances go up. All starters will eventually do what yours is doing given enough time as the aging process degrades insulation and internals.
To c5 starting problem need help
