engine support fixture and proper location
Old Mar 28, 2015 | 04:23 PM
tripz's Avatar
tripz
Default Where do you support engine from above w engine support?
Anyone know where to hook the engine support fixture to the engine? In the process of dropping lower cradle and need to properly support the motor from above
tia
Old Mar 30, 2015 | 04:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I did mine on jack stands and supported it from the balancer and after the cradle was removed, put the stands on the engine mount tabs that bolt to the block.
While the cradle is out, make sure that you carefully inspect the engine mount rubber cushions for cracks and wear.
BC
Old Mar 30, 2015 | 05:41 PM
Johnny wangwang's Avatar
Johnny wangwang
That is the LAST place id support the motor. I use two longer grade (whatever the strongest bolts are) bolts and replaced the two middle oem bolts on the valley cover. Then I use a cherry picker to support and or pull the motor
Old Mar 30, 2015 | 05:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ahhhhhh, It didnt hurt a thing!
Old Mar 30, 2015 | 06:01 PM
Johnny wangwang
double post
Old Apr 3, 2015 | 01:16 PM
tripz's Avatar
tripz
BC
I didnt have time to research and discover spots for the engine support so I ended up dropping subframe on rhino ramps and supported the motor by the flywheel clutch assembly on wood platform supported by transmission jack.
Everything worked out well and hopefully Ive corrected any leak. Nothing spotted so far
To engine support fixture and proper location
