CD changer :(
Old Apr 8, 2015 | 06:39 AM
thompsonc3's Avatar
thompsonc3
Originally Posted by Chicago1
All his stuff is plug and play and made for the vette he has packages and can do custom from mild to wild. Great vendor
What kind of set up did you do to take place of the CD changer.
Old Apr 8, 2015 | 11:09 AM
Chicago1's Avatar
Chicago1
Pioneer 6" touch screen dvd player, navi, gps, etc etc, JL audio 12w6 sub, JL 500.1 amp and all JL audio front and rear speakers and of course the modified double din to fit the radio like it came like that from the factory
Old Apr 8, 2015 | 11:28 AM
73Corvette's Avatar
73Corvette
Call Dennis at Double D... unless your a very picky audiophile, the factory system sounds pretty good IF your not using the FM transmitter. They make a plug and play Peripheral PXDP PXHGM2 Chevrolet Corvette 97-04 iPod Adapter
up grade speakers and your set! Money saved to spend on Performance mods!
Old Apr 8, 2015 | 12:29 PM
thompsonc3's Avatar
thompsonc3
That sounds good. What kind of money for a system like that.
Old Apr 8, 2015 | 03:34 PM
eevette2001's Avatar
eevette2001
wtf is a cd player?...get rid of that dinosaur and upgrade!!! Double D will hook you up!! Bring you into this century
The CIGARETTE ASHTRAY too!!
Old Apr 8, 2015 | 04:08 PM
Chicago1's Avatar
Chicago1
I think for the double din and plug and play was around 700 maybe cheaper then I added everything after so maybe 1500? he has a crap load of packages from inexpensive to I have money to burn. I like my music loud and chest thumping bass and I got it.
http://shop.doubledmods.com/C5-CORVETTE-97-04_c137.htm
Chicago1's Avatar
Chicago1
My methanol panel goes there now.
Old Apr 8, 2015 | 04:32 PM
73Corvette's Avatar
73Corvette
So,, are you running stock exhaust? You can't hear it anyway.
Old Apr 8, 2015 | 04:59 PM
thompsonc3's Avatar
thompsonc3
That's awesome. I will definitely check in to it. Thank you. I like mine loud as well.
Old Apr 8, 2015 | 07:13 PM
Chicago1's Avatar
Chicago1
Procharger D1SC 11psi, 1 7/8, 3" xpipe B&B Prt's and a 50mm Tial Bov..It's LOOOUD even with the tunes blasting
Old Apr 9, 2015 | 04:06 PM
thompsonc3's Avatar
thompsonc3
Originally Posted by SoaringFreak
The other option if you don't want to jack with CD's is get one of those plug in's that you can attach an Ipod or phone by cable to your changer. You can still control it through your stock head in the dash. I love mine and not limited to just the music a the CD's.
That's pretty cool. Might have to check that out. Thanks
Old Apr 9, 2015 | 04:10 PM
eevette2001
CD changers all over the net for $100, same model. That's what did when mine jammed.
Old Apr 9, 2015 | 07:36 PM
  #33
thompsonc3's Avatar
thompsonc3
I'm gonna try to get mine fixed. Or just upgrade.
Old Apr 9, 2015 | 07:40 PM
  #34
73Corvette's Avatar
73Corvette
But to use this one you have to have the CD changer it just uses the wires from the changer....still plays through the factory head unit...
That's why I posted this...
Old Apr 9, 2015 | 07:52 PM
  #35
thompsonc3's Avatar
thompsonc3
O ok. Thank you. I have a lot of different options to weight out. I love this corvette forum. Alot of good ideas from a bunch of corvette lovers. Pretty cool.
Old Apr 9, 2015 | 07:59 PM
  #36
73Corvette's Avatar
73Corvette
Yup, it is an awesome place... I would be a C5 idiot if it wasn't for the forum. Have fun and good luck. Call Dennis he is awesome and won't pressure you at all, and will answer any and all questions you might have about audio and what you can do in a C5
Old Apr 9, 2015 | 08:18 PM
  #37
thompsonc3's Avatar
thompsonc3
Thank you.
To CD changer :(
Old Apr 10, 2015 | 02:16 AM
  #38
85Coupe4+3's Avatar
85Coupe4+3
Just a thought--have you tried a new magazine? They are pretty cheap, and the magazine is more prone to failure than the internals of the unit . . .
Old Apr 10, 2015 | 06:47 AM
  #39
thompsonc3's Avatar
thompsonc3
No I haven't. It loads up just fine. The player just won't spin the CD.
Old Apr 20, 2015 | 10:38 AM
  #40
shredhead1080's Avatar
shredhead1080
slightly different question.
I removed my cd changer since I was not using it.
There are 4 bolts sticking out from where the brackets were connected to the car. Is there a way to remove those? I don't want to cut them off in case one day I decide to sell the car and return it to stock. (I left the wiring harness for the cd changer for that reason as well.)
