Tubbing ..... Does it really help ??
Old Aug 12, 2002 | 01:34 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Tubbing ..... Does it really help ??
Hi guys ,
i know there are several forum members that have decided to "TUB" there wheel wells in an effort to improve traction.
Is this MOD worth the money ? Did you really notice a significant difference ?
:cheers:
Old Aug 12, 2002 | 01:47 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Tubbing ..... Does it really help ?? (BLUTHUNDER)
I went from the stockers in back to 18x12 with the tubbing done by LGM. The traction difference is night and day with the 335's out back, on the street and at the track. Well worth it for performance reasons, not just show. :cheers:
Old Aug 12, 2002 | 02:07 PM
01C5fan's Avatar
01C5fan
Definitely a big improvement over stock run-flats. A better comparison might be to the same tire in 295/35 which will fit fine without tubbing. I'm not sure it would be nearly as big a difference then. I run 335/30/18 Hoosiers at the track (hpde events) and they stick like glue. I also like the look of the wider tire. I'm glad I did it, but if your only criteria is performance, I'm not sure it's all that cost effective.
Old Aug 12, 2002 | 08:21 PM
tscales's Avatar
tscales
St. Jude Donor '07
Default Re: Tubbing ..... Does it really help ?? (01C5fan)
I don't think it is worth it. I run 335s on 18x11.5 without tubbing. The difference between that and a tubbed car is too small for the investment.
Tom
Old Aug 12, 2002 | 08:27 PM
Untouchable00's Avatar
Untouchable00
Default Re: Tubbing ..... Does it really help ?? (tscales)
What does tubbing consist of??
Old Aug 12, 2002 | 08:29 PM
MelloYellow's Avatar
MelloYellow
Tubbing is a visual mod and depends how picky you are on visuals and how you like the look.
Going to a 335/30-18 is a huge difference in braking, traction and handling.
Old Aug 12, 2002 | 08:40 PM
tscales's Avatar
tscales
St. Jude Donor '07
I'm confused. How is tubbing a visual mod? It's just cutting out the rear wheel wells and fiberglassing in wider wheel wells.
Tom
To Tubbing ..... Does it really help ??
