Antenna Options
Old Aug 12, 2002 | 01:36 PM
deano24's Avatar
deano24
Default Antenna Options
Is there a way to disable the antenna when I am only using the CD player? It seems to me that if I am only using the CD player the antenna should not have to come up! Other cars operate this way. I guess I could pull the fuse but then of course I will have no radio!
Old Aug 12, 2002 | 01:46 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Antenna Options (deano24)
Instead of pulling the fuse everytime you could wire in a on/off switch to the antenna.
Old Aug 13, 2002 | 03:56 AM
AKFINEST's Avatar
AKFINEST
My 2002 Coupe does not have a power antenna. I believe it is built-in the windshield. BTW, Mid America sells a kit for the 1997-2002 (Item#601-252 Bypass Harness) and Ecklers (Item#41211) for $19.99
Old Aug 13, 2002 | 01:23 PM
deano24's Avatar
deano24
Default Re: Antenna Options (AKFINEST)
Thanks for the info, I ordered the part from Mid-America and I hope I don't have mess with the original equipment too much!
To Antenna Options
