Active Handling Warming Up
Old Apr 3, 2015 | 02:26 PM
VETSTYL's Avatar
VETSTYL
Default Active Handling Warming Up
Just had some suspension work done. New shocks, new tie rods all the way around, new end links, power steering rack replaced and a front end alignment. Parts replaced because all original in a 2000 and power steering rack had a leak. I can feel the steering is "tighter". However, I'm now getting getting the error message and then it goes to Service Active Handling.
Is it reasonable to presume the work done caused the Active Handling Warm Up message.
Old Apr 3, 2015 | 04:03 PM
65GGvert's Avatar
65GGvert
It's reasonable, and I'd suspect an issue with the centering on the steering wheel position sensor. With the key on, clear any messages on the DIC, press and hold the options button and press "fuel" 4 times while holding. Write down the codes that come up and post them here. If they go too fast, you can step back through them by pressing the reset button momentarily.
