dic problems
Old Apr 5, 2015 | 01:07 PM
Scott Luttrell's Avatar
Scott Luttrell
Default dic problems
I posted this before and got nowhere. I replaced the dic buttons on 99 . worked well for a couple days and then lost everything. no odometer, no head up, no nothing, can anyone help me with this ? thanks
Old Apr 6, 2015 | 12:01 PM
dadaroo's Avatar
dadaroo
Like I said previously, I think your IPC is bad. You should be able to disconnect the DIC button switch and still have normal functions except for using the DIC buttons.
Old Apr 6, 2015 | 01:20 PM
Scott Luttrell
sorry, i didn't see your reply. I'm selling the car and i want it to be right. how do i check the ipc? or is it something a dealership would have to check.
Old Apr 7, 2015 | 07:16 AM
dadaroo's Avatar
dadaroo
Suggest you get a used IPC. If you can install a DIC switch you can install an IPC. You will just need to have the odometer mileage reset. A shop or dealer can do that.
MAKE SURE a replacement is HUD compatible.
Try Marc at VetteNuts.com
Old Apr 7, 2015 | 11:44 AM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
What is the mileage on the car. We have dozens of complete clusters in stock. That would be the simplest and quickest.
Marc
Old Apr 7, 2015 | 11:52 AM
dadaroo's Avatar
dadaroo
Thanks again Marc. That is why I always recommend you as the first point of contact.
Scott, if you want a shop to do it I can recommend one in Summerville and they can reset the mileage too. They could do it in a couple of hours easy.
To dic problems
