HELP: P1441 (check engine)
Old Apr 5, 2015 | 07:45 PM
bizzmeister's Avatar
bizzmeister
St. Jude Donor '15
Default HELP: P1441 (check engine)
Hi guys,
Randomly received this message the other day while driving after the check engine popped up. I turned the car off and checked the DIC and it shows p1441 C ( for current )
I immediately first checked the gas cap and it was old and worn so I replaced it with an OEM gas cap and reset the check engine light. I've driven about 300 miles since resetting it.
Fast forward to today, it popped up again while driving normally to the store. What am I looking at here? Some sort of EVAP issue? Any help is appreciated!
-Bizz
Old Apr 6, 2015 | 11:39 AM
bizzmeister
St. Jude Donor '15
Anyone?
Old Apr 7, 2015 | 02:34 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
@P1441 Evaporative Emission (EVAP) System Flow During Non‐Purge
This is from DTC codes list,, do a search on the forum,,lot of information...
Old Apr 19, 2015 | 01:46 PM
73Corvette's Avatar
73Corvette
Old Apr 19, 2015 | 05:05 PM
bizzmeister
St. Jude Donor '15
Originally Posted by 73Corvette
Was the stupid evap purge solenoid bought one new from GM parts locally for $59, took about 10-15 minutes to replace the original one that went bad.
Smooth sailing since
Old Apr 19, 2015 | 06:20 PM
73Corvette's Avatar
73Corvette
Glad you got it fixed and thanks for posting your resolution....
Old Apr 21, 2015 | 10:18 AM
1slowride's Avatar
1slowride
Default for sure
I second this...... THANKS FOR POSTING YOUR RESOLUTION.
Old Apr 21, 2015 | 02:28 PM
73Corvette's Avatar
73Corvette
Originally Posted by bizzmeister
Hi guys,
-Bizz
Just FYI to get current codes you should pull them BEFORE you kill the car...
Old Apr 24, 2015 | 07:51 PM
ZZ06's Avatar
ZZ06
I a lot of guys aren't aware you can run a diagnostic check while the car is still running. You don't have to shut her down.
Old Oct 1, 2023 | 01:29 PM
grinder11's Avatar
grinder11
Indeed! I've been told that some codes may not show up when the engine is not running.....
Oooops!! Old thread, but at least my response may help someone.....
To HELP: P1441 (check engine)
