853 vs 241's
Old Apr 6, 2015 | 04:13 PM
2ooo-C5's Avatar
2ooo-C5
Default 853 vs 241's
Im a pretty sure I trashed my rings. Will know for sure in a couple
days when I do some more testing.
That means I have to rebuild the engine a lot sooner then planned.
I don't have a budget, but while the heads are off they have to get work done.
Being a 2000, it should have 853's. Would rather save the money
and just work over the 853's that I have, if buying some 241's
will only get me an extra 10 hp. How much better do they really flow?
I have read they are almost identical.
I'm not changing ports. I have brand new steal work headers on it.
Not going to replace those to change head styles.
Can not afford AFR's at this time.
Old Apr 6, 2015 | 04:37 PM
JT FRC 00's Avatar
JT FRC 00
My 2000 came with 241's but recently yanked them off. Installed 317 heads and a cam. Being that you have a blower already it gives you options basically. I honestly don't see any difference between 853 & 241 heads. You might be able to pick some 241's up cheaper than getting yours worked over. I went with 317's to lower the compression a little and up the boost.
Old Apr 6, 2015 | 04:39 PM
2ooo-C5's Avatar
2ooo-C5
Will the same headers work?
I know very little about LS1 heads. I know everyone
wants the new heads but I am not buying another set of headers.
Will be doing a fully forged bottom end. It will just sit till I have the right parts. I don't like pulling motors.
Old Apr 6, 2015 | 04:40 PM
2ooo-C5's Avatar
2ooo-C5
I can get a pair of 317 for $300.
Old Apr 6, 2015 | 04:53 PM
JT FRC 00's Avatar
JT FRC 00
Yes the headers will work just fine, the exhaust ports are the same. Also the 317's are for a 6.0 liter with a 4in stroke. Meaning you will need to use a head gasket for the head. I used LS7 head gaskets on mine. Is your car an auto or 6 spd? Some people said they noticed midrange power loss with an auto going with these heads. I have a 6 spd so I can't see any loss at all
Old Apr 6, 2015 | 04:56 PM
2ooo-C5's Avatar
2ooo-C5
6 speed.
Old Apr 7, 2015 | 04:20 PM
Anthraxmm's Avatar
Anthraxmm
853 and 241 are the same heads. They're just cast different. You will see likely 0 difference in power. All ls headers will bolt up to all ls heads. The intakes however are different.
To 853 vs 241's
