Guide for engine removal?
Old Apr 8, 2015 | 04:42 PM
2ooo-C5's Avatar
2ooo-C5
Default Guide for engine removal?
I have searched, and searched.
I have found lots of videos after the engine is out.
I have found guys who have take the engine out the side,
out from under the car... pretty much everything.
Except a guide telling you how to drop the cradle and remove the engine.
I have never tried to take an engine out from under a car.
Old Apr 8, 2015 | 11:56 PM
Armycop's Avatar
Armycop
Default the googler is your friend...
if you know it's language. typed "C5 engine removal", this was on the first page. http://www.superchevy.com/how-to/cor...ngine-removal/
Plenty of info out there.
Old Apr 9, 2015 | 09:30 AM
2ooo-C5's Avatar
2ooo-C5
Did you read it?
I did they skip over everything.
You click read full article and you get a couple sentences.
Once the shifter is removed, the vehicle can be put on a two-post lift, and the drivetrain component and system removal process can happen.
Yep that sure tells me how to do it....
I checked the first 5 pages of google... nothing but crap.
Old Apr 9, 2015 | 10:07 AM
NVESTZ06's Avatar
NVESTZ06
Are you using a lift? or in the garage?
If no lift, we will go out the top. If this is the case, let me know and I will walk you through the steps from memory.
Old Apr 9, 2015 | 10:12 AM
2ooo-C5's Avatar
2ooo-C5
Dude I will love you forever, if you can do that....
I do not have a lift.
I had not decided best way to get it out. I read of guys taking it under with large jack stands.
I so do not like that idea. Out the top sounds so much better to me.
Old Apr 9, 2015 | 01:15 PM
zachaeous's Avatar
zachaeous
Default engine removal
I just finished removing the engine from my 2001 from the top. I have the car on jack stands and dropped the cradle, pulled the engine with a engine lift. It was no harder than pulling the earlier model cars except having to drop the cradle.
here is a link to a procedure for pulling engine from the top:
http://web.archive.org/web/201012091...engineswap.htm
hope this helps
Old Apr 9, 2015 | 01:36 PM
2ooo-C5's Avatar
2ooo-C5
hope this helps
Link doesn't work for me.
503 Service Unavailable
I found that link in google... but someone let the domain expire.
Old Apr 9, 2015 | 02:38 PM
zachaeous's Avatar
zachaeous
Default link
I just checked the link and it works for me. this a link for the whole achieve
http://web.archive.org/web/201012091...c5techhome.htm
Old Apr 9, 2015 | 03:05 PM
2ooo-C5's Avatar
2ooo-C5
weird... it works for me this time.
To Guide for engine removal?
