Exhaust manifold removal? Need help now!
Old Aug 12, 2002 | 09:47 PM
QuickSilver2002's Avatar
QuickSilver2002
Default Exhaust manifold removal? Need help now!
I’m tying to install my headers and having problems getting the exhaust manifolds off. I think I have removed all of the bolts, but it is not giving at all. Any hints!
Also a little concerned about how I will guide the dipstick back in place, since I had to remove it. Any hints on this would also be appreciated.
Old Aug 12, 2002 | 10:15 PM
yelloz06's Avatar
yelloz06
Default Re: Exhaust manifold removal? Need help now! (QuickSilver2002)
Did you check the lower bolts. They are top and bottom alternating. Check with a small mirror. If all are removed, tap with a rubber mallet.
The Dipstick will need to be tweeked ever so gently (be careful so you don't crimp it). Use a small open end wrench that will stay above the seat ring on the exterior of the tube to allow you to push it the rest of the way home.
:cheers:
Old Aug 12, 2002 | 10:21 PM
QuickSilver2002
Default Re: Exhaust manifold removal? Need help now! (yelloz06)
Thanks Yello,
I just noticed the hidden one after reading your reply. I can't belilve I missed that one!
Thanks again!
[Modified by QuickSilver2002, 2:22 AM 8/13/2002]
To Exhaust manifold removal? Need help now!
