Can I uprgade climate control
Old Aug 13, 2002 | 12:47 AM
Quick Brick's Avatar
Quick Brick
Default Can I uprgade climate control
Is it possible to upgrade manual a/c controls with a dual a/c controler and maybe a computer flash?? Thanks! :seeya
Old Aug 13, 2002 | 01:19 AM
SAXN8R's Avatar
SAXN8R
Default Re: Can I uprgade climate control (Quick Brick)
I think it would be cheaper to trade the car in for a new one w/ the auto a/c controls. No joking either. Jschindler, a forum member looked into doing the opposite, and it was more trouble and expense than it's worth. Trust me, you are not missing much with the auto temp control. I don't think even the GM engineers know how this thing works. Most of us can't even get the a/c compressor to turn off if we want it to. The only thing I would miss if I had the manual controls is the OAT guage. (outside air temperature)
[Modified by SAXN8R, 11:19 PM 8/12/2002]
Old Aug 13, 2002 | 01:18 PM
ersatz928's Avatar
ersatz928
Default Re: Can I uprgade climate control (SAXN8R)
Why would you want to replace the manual controls with a complex, trouble prone system that sometimes has a mind of its own??
Old Aug 13, 2002 | 02:05 PM
Quick Brick
Default Re: Can I uprgade climate control (ersatz928)
Just for looks mainly. Even though this car will be for racing and fun. I had the dual air in my 98 and it worked fine 100K miles. At 75K I had to replace the dash unit because the LCD disappeared. I will probably stay with stock though. Gives it that base GM yet functional look :D
To Can I uprgade climate control
