Diff Gear Help
Old Apr 12, 2015 | 05:16 PM
HardcoreABN's Avatar
HardcoreABN
Default Diff Gear Help
Anyone able to help decipher these numbers on my Motive pinion gear? The only numbers on the ring gear is "68B"
The only truly readable number on the pinion is "68B".
any idea what that other mess is? This is the first time I have done gears where the A1 and A2 values weren't overly obvious.
"68B" could be the A2 value of 68mm, but that would be a big difference from 65.5mm Assuming that 68B is the matched gearset serial number, where would be no value listed for A2.
The other mess could be 4.0554 with the first "4" upside down which would be really ****ing odd. Plus to have both metric and standard specs would be odd as well. if that is really h .0554 that leads to other questions....
Any ideas?
