Lowering
Old Aug 13, 2002 | 08:33 AM
LemonESQ's Avatar
LemonESQ
Default Lowering
Those of you who have lowered your C5s and drive them regularly, please advise whether you would recommend it or not and why. Any particular application recommended? :cheers:
Old Aug 13, 2002 | 11:38 AM
RDRH8R's Avatar
RDRH8R
Default Re: Lowering (LemonESQ)
I lowered my 99 and love it. I did not cut any bushings or use lowering bolts just loosed the rear and tightend the front. You can tell by looking at it that it has been lowered. I did not lose any drive comfort. Only drawback is that I am more aware of steep drives and high speed bumps. :D
Old Aug 13, 2002 | 12:17 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Lowering (RDRH8R)
I lowered mine this past weekend. I got longer bolts in the back and left 8 threads showing. In the front I cyt 2/3's of the bushing off. I love it!!!!!! I think it rided better now then it did before. It is a stiffer ride now. Like he said you have to watch out for bumps and driveways. Kaley
Old Aug 13, 2002 | 12:22 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Lowering (2C5only21)
Longer bolts and cut bushings, what do I think of it? :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :D
Old Aug 13, 2002 | 06:00 PM
Stingray1967's Avatar
Stingray1967
Mine SEEMS to ride a little harsher, but the slight improvement in handling and BIG improvement in looks is worth it. Plus, it is TOTALLY reversable if you don't like it. :yesnod:
Old Aug 13, 2002 | 07:51 PM
Lynn2008's Avatar
Lynn2008
Default Re: Lowering (Stingray1967)
Its a must!!!
Old Aug 13, 2002 | 08:58 PM
wickedvette's Avatar
wickedvette
Cruise-In II Veteran
Low is the only way to go.....and looks very :cool:
I lowered as far as possible without cutting bushings (front) or using longer bolts (rear).
Old Aug 13, 2002 | 08:59 PM
99NassauVette's Avatar
99NassauVette
Default Re: Lowering (ericg320)
I really want to lower mine.. but still have my woes on my car being f45. Just a question.. you loosen the bolts in the front and tighten in the back? Im confused lol
Old Aug 13, 2002 | 10:27 PM
LemonESQ's Avatar
LemonESQ
Thanks looks great! I am mostly worried about the road dip concerns, but it sounds as if that's not overly burdensome.
Old Aug 13, 2002 | 10:28 PM
LemonESQ's Avatar
LemonESQ
Default Re: Lowering (racer44)
I think that looks great! Thanks.
Old Aug 13, 2002 | 10:56 PM
rpoz06's Avatar
rpoz06
Lowered to the limit with stock bolts (see sig) but w/ new HRE's on the way I am definately going to go with longer rear bolts and cut the front bushings. racer44 is my HERO!!! :lol:
Old Aug 13, 2002 | 10:57 PM
team5150's Avatar
team5150
I just lowered mine this weekend by cutting 2 front bushings and using 6" bolts in the rear. I also installed Bilstein's and Hotchkis sway bars.
This is how a Corvette SHOULD be ! I will post some before and after pix as soon as I can. If you're thinking about it - do it ! You won't regret it.
To Lowering
