Where is the A4 trans fill plug located?
Old Apr 15, 2015 | 02:39 PM
randerson0248's Avatar
randerson0248
Default Where is the A4 trans fill plug located?
Car is up on stands now, plan to do a fluid and filter change.
The oil pan has a drain plug on the side. Is this plug on the side of the oil pan where the full level is checked?
It seems to me to be to low for this to be the level for a full transmission.
Old Apr 15, 2015 | 03:06 PM
junk c5's Avatar
junk c5
http://www.corvetteactioncenter.com/...automatic.html
Old Apr 15, 2015 | 03:39 PM
randerson0248
Thanks for the link, but it did not answer my question about whether the plug in the pan is the fill plug.
One poster in the link said that the fill plug is on the side of the transmission. I can't locate a plug on the transmission, only the pan.
Old Apr 15, 2015 | 04:49 PM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
For A4 transmission:
The drain plug is also the fill plug.
http://www.corvetteforums.com/forum/...d-check-13638/
For manual:
Old Apr 15, 2015 | 05:30 PM
junk c5's Avatar
junk c5
Drain and fill from the same bolt on the drivers side of the pan . Drop the pan and change the filter .
To Where is the A4 trans fill plug located?
