which headlight bulbs??
Old Apr 16, 2015 | 09:47 PM
bwill03z's Avatar
bwill03z
Default which headlight bulbs??
I replaced my low beam lights, which were the cheap base model sylvania bulbs, with the sylvania ultra brights. The difference was very minimal and still not nearly bright enough. What are the best bulbs to get?
Old Apr 16, 2015 | 10:25 PM
bwill03z's Avatar
bwill03z
Originally Posted by 8VETTE7
I have tried many different "bulbs" in the factory housings including some very high wattage ones. None of them made the difference I was looking for. I finally went to HID Projector setups on my car and the difference is HUGE. I have had mine for a bit over a year and a half... A couple Forum vendors sell the projector conversion setups last I checked.
I may have to go this route. What all has to be done to switch as far as wiring?
Old Apr 18, 2015 | 11:32 AM
john8642's Avatar
john8642
I am very satisfied with the 9011/9012 HIR bulbs. They're the brightest non HID bulbs available, and made a big improvement over the stock ones. I also added the 4-HI harness to use all four bulbs on high beam. Candlepower Inc. sells the bulbs for about $50.00 a pair.
Old Apr 18, 2015 | 11:52 AM
rws.1's Avatar
rws.1
I did the Silverstars, then the HIR,s ... HID is the way to go.
The kits are plug and play. You need to install ( double sided tape) a ballast between the current light harness and the new bulb.
The kits contain the ballast with the correct connectors to mate with the wiring harness along with the HID bulb that fits into the headlight housing. 30 minute job.
Old Apr 18, 2015 | 01:49 PM
jackthelad's Avatar
jackthelad
Big jump in price between a $50 pair of bulbs and a projector conversion. Anyone have any experience on the HID conversion kits? I assume they are not too good, as the US C5 beam pattern is not well controlled to start with.
Or a strict comparison between HID projectors and Euro lens and hi power bulbs?
Old Apr 19, 2015 | 02:39 AM
Cliff8928's Avatar
Cliff8928
I used the 9011 bulbs for the low beams in my Saab and my dad's Explorer (both are factory projectors with 9005 bulbs). I probably would've done the same in my C5 if I didn't go with fixed headlights because the stock ones were vibrating which I found irritating.
Old Apr 19, 2015 | 06:20 AM
SG Lou's Avatar
SG Lou
But does this require you to also change to those butt ugly bug eye reflector lens ?
Old Apr 19, 2015 | 10:32 AM
mike_engr's Avatar
mike_engr
Try a HID bulb conversion and 4-hi harness like I did. Huge difference at night. Just adjust your beams down a little to insure you don't blind anyone with scatter.
No ones complained about mine and I've driven behind friends and asked...
If you drive a lot at night and want the best, get the full projector conversion! I'm sure it would make HID even better! I'm very happy so far with the improvements I've made at minimal cost. HID of some sort is the "only" way to go!
edited to add HID+4HiLo pic:
To which headlight bulbs??
