Dead dash / No fire
Old Apr 23, 2015 | 01:14 PM
lmrace's Avatar
lmrace
4th Gear
Default Dead dash / No fire
I have a 2001 C-5 convertible. One in about 20 times I go to start the car and the dash is completely dead and the motor wont fire, if it does it seems to be running in limp mode. Everything else that's electrical is fine. It's not throwing any codes. Is anyone else having this problem?
Old Apr 23, 2015 | 03:05 PM
Macleod52's Avatar
Macleod52
Have you checked the battery?
Old Apr 23, 2015 | 03:25 PM
lmrace's Avatar
lmrace
4th Gear
Battery is only 1 month old. The motor cranks just fine and everything electrical works except the heads up display and the gauge pod. When it does start the heads up still isn't working. Its very intermittent. I just went through the chassis grounds, cleaned them.
Old Apr 24, 2015 | 10:49 AM
dadaroo's Avatar
dadaroo
Not at home but I wonder if you are having ignition electrical switch issues.
I can give you the fuses to check to see if the switch is dropping the voltage and causing this issue. Very common problem. Can you use a voltmeter?
I can look later and see where the IPC grounds are but I doubt that is your issue.
We need to focus on why it will not run. That may resolve the IPC issue.
Old Apr 24, 2015 | 01:09 PM
lmrace's Avatar
lmrace
4th Gear
I have just about any tool needed to do any thing to my cars and know how to use them.(until now!!!!) I did run the onboard diagnostics and came up with numerous codes the most frequent one was U 1016 which is a loss of communication with PCM and a lot of low voltage codes. Its strange how my $900.00 diagnostic tool doesn't read any of these codes. On board says I have 6.7 volts at PCM and volt meter says I have11.9 at battery at the same time and 11.8 where the battery cable connects with the starter. Am I correct in assuming that I loosing power between the distribution box or ign. switch and the PCM ?
Old Apr 25, 2015 | 06:25 AM
dadaroo's Avatar
dadaroo
Your car will never work at those voltages.
A fully charged battery should be 12.6v or more.
If the battery is
12.5 = 85% charged
12.4 = 65%
12.3 = 50%
12.2 = 35%
12.1 = drained
To Dead dash / No fire
