installing shorty headers
Old Apr 26, 2015 | 10:26 AM
wagner262's Avatar
wagner262
Default installing shorty headers
anyone have any tips on getting the driver side header in? Ive got the other side in and cant seem to get the driver header in.
I have taken the alternator off and unbolted the engine from the engine mount so I could move the engine a little more. I cant seem to squeeze it in. any tips?
Old Apr 26, 2015 | 10:44 AM
c5blackvett's Avatar
c5blackvett
What headers do you have?
I may do the same project so please tell what is your set up...stock.
What I have read is that some lower the motor cradle a little to get the headers in.
Also see this write up.
http://www.ls1howto.com/index.php?article=29
Good luck.
Old Apr 26, 2015 | 12:03 PM
wagner262's Avatar
wagner262
I have pace setters. I guess Ill try going from underneath... just didnt want to take off the mid pipe..
Old Apr 27, 2015 | 09:36 PM
dcastellano71's Avatar
dcastellano71
I took off valve cover to get mine on. I have the BBK ones.
Old Apr 28, 2015 | 12:40 AM
ImmortalC5's Avatar
ImmortalC5
After you get them installed let us know of the performance of the shorties. And how are the bbk shorties?
Old Apr 29, 2015 | 12:17 AM
wagner262's Avatar
wagner262
As far as installation goes the passenger side fell right into place from above pretty easy. Driver side was harder but if I did it a second time it would be a breeze.
I went from the top all I did was remove the alternator unbolt the 3 bolts on the engine mount jack the engine up and the headers slipped in. I tried unbolting the hpipe and sending the headers from under but couldn't figure it out. My suggestion would be to go from the top....
Performance wise I notice it a little bit. Feels like it has more torque. The sound is absolutely amazing! I don't regret the long hours and busted knuckles at all. I live in cali so long tubes were a no go. I've had long tubes before and the sound is close which is cool to my current set up. Obviously the LT are better but I'm happy with the outcome being it's all smog legal.
Cheers!
Old Apr 30, 2015 | 04:20 AM
dcastellano71
BBK Shorties are coated and fit nicely. Really changed the way the car sounds with my Corsa extreme exhaust. Much deeper sound, lots of low end torque.
Old May 12, 2015 | 12:32 AM
onemortoy's Avatar
onemortoy
Default Shorty headers
I put BBKs on my 04 with no issue durning install. Just pulled the altinator, and dropped them in. I do see more bottom end and a little better sound.
To installing shorty headers
